steel vacuum lines under the manifold..easy removal?
5 replies to this topic
#1 hatchsub
hatchsub
    Currently Subaru-less :(
  • 2,714 posts
  • Guilford
Posted 25 September 2006 - 09:34 PM
Is there an easy way of removing these lines from under the manifold. If i was to convert to a weber i would want to clean up the underhood appearance a bit. anyone got an opinion on this one? Is there enough space to slip them out and unbolt them without taking the manifold off again. I know im just being lazy so sue me lol.
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,624 posts
  • Portland
Posted 25 September 2006 - 09:59 PM
Nope - have to take the manifold off. Use new gaskets FROM THE DEALER. Trust me on this one.
#3 hatchsub
hatchsub
  • 2,714 posts
  • Guilford
Posted 25 September 2006 - 10:33 PM
yeah thats what i was afraid of. Thanks for the quick response. Ive already gone through pulling this manifold and i used the dealer gaskets and your right..they are the only way to go.
#4 TomRhere
TomRhere
    Certified BRAT nut!!!
  • 4,600 posts
  • Hillsdale, Mi. USA
Posted 26 September 2006 - 03:05 AM
If one does not care about ever using the tubes again, they can be removed without pulling manifold. You have to bend the crap out of them, and I think I had to cut one or two, but they can be removed with manifold on.
#5 GeneralDisorder
GeneralDisorder
  • 21,624 posts
  • Portland
Posted 26 September 2006 - 03:24 AM
EA82 ones probably could be - but there's a couple bolts on the EA81 manifold that I'm pretty sure you couldn't get to without pulling it. But I might be wrong. I too tried this a long time ago. The bolts on the EA82 manifold are on the sides, and two of the the EA81 bolts are on the bottom where a wrench will not fit.
#6 Jerry DeMoss
Jerry DeMoss
    Pushrods 'O' Fury
  • 2,408 posts
  • Colorado
Posted 26 September 2006 - 07:50 AM
Agreed.I noticed that as well when working on either manifold.Ea81 definately needs to be pulled.
