wilsrobe Posted September 28, 2006 Share Posted September 28, 2006 Hi bought a 1600 out of airplane hanger, its been sitting for 20yrs, how would i prime the oil before starting and anything else I should do frist?. Thanks Robert Quote Link to comment Share on other sites More sharing options...
mtsmiths Posted September 28, 2006 Share Posted September 28, 2006 Hi bought a 1600 out of airplane hanger, its been sitting for 20yrs, how would i prime the oil before starting and anything else I should do frist?. Thanks Robert Well, the old time pepper tree mechanic in me says: Drain and replace the oil, replacing 1/2 QT with Marvel Mystery oil. Remove all the spark plugs, squit MMO liberally into each cylinder. With the plugs out, crank the engine , you can squirt a bit more MMO into each cylinder as you go to lube up the cylinder walls and help free up the rings. Put the plugs back in and see how it runs. After a couple hundred miles change the oil and filter again. Done that on many cars that have been sitting, and a couple of airplanes. If there is any Subaru specific tricks I don't know about, or if I've steered you wrong, someone will jump in here and let us both know. Quote Link to comment Share on other sites More sharing options...
wilsrobe Posted September 29, 2006 Author Share Posted September 29, 2006 thanks I'll do that, but what about the bearings will they get oil quick enough? Robert Quote Link to comment Share on other sites More sharing options...
mtsmiths Posted September 29, 2006 Share Posted September 29, 2006 thanks I'll do that, but what about the bearings will they get oil quick enough? Robert "With the plugs out, crank the engine" That's why this part, the starter will spin the engine fast enough to get oil throughout the engine because there's no compression. There's also very little strain on the bearings for the short time that they are running dry. You also get the chance to listen for any gawdawful noises before running it. :-p Quote Link to comment Share on other sites More sharing options...
DerFahrer Posted September 30, 2006 Share Posted September 30, 2006 The engine should actually spin slower with the plugs out, because the compression kickback won't help the engine along. Instead of pulling the plugs out, just pull the wire off the coil, then crank the engine for about 20 seconds or so. Quote Link to comment Share on other sites More sharing options...
keltik Posted September 30, 2006 Share Posted September 30, 2006 Im with mtsmiths on this one, having the plugs out is the best idea to reduce the stress on the bearings etc. Also saves you hydrolocking the engine with too much oil. Also saves you from fouling the plugs i guess. Let us know how you get on! Quote Link to comment Share on other sites More sharing options...
DerFahrer Posted September 30, 2006 Share Posted September 30, 2006 Huh? What would oil be doing in the cylinders? Quote Link to comment Share on other sites More sharing options...
keltik Posted September 30, 2006 Share Posted September 30, 2006 From the second post in the thread: Remove all the spark plugs, squit MMO liberally into each cylinder. Quote Link to comment Share on other sites More sharing options...
wilsrobe Posted October 1, 2006 Author Share Posted October 1, 2006 thanks for advice, but engine is no good will turn a little each way and stops, thinks its a rod. Robert Quote Link to comment Share on other sites More sharing options...
