WJM Posted November 10, 2003 Share Posted November 10, 2003 Enjoy! http://free.inkfrog.com/pix/wmaham1701/deltacam.jpg Quote Link to comment Share on other sites More sharing options...
JWX Posted November 10, 2003 Share Posted November 10, 2003 did you get them installed yet? Quote Link to comment Share on other sites More sharing options...
WJM Posted November 10, 2003 Author Share Posted November 10, 2003 No. Awaiting CU HGs from CA. I also have much work left before I put the engine back together. Finnish cleaning heads. Dissasemble heads. remove all gaskets and seals from the engine. Finnish cleaning engine. Inspect engine. install NEW gaskets and seals. reassemble the heads. Receive CU HGs, and lighten'd flywheel. install those components. Install cams. Install and swap over thingys for the spyder intake to go into a non spyder car. Take old engine out. install new engine and swap some more things over. Run engine. Burn those rice boys in their boy racer rice cars to the ground. Oh, and THEN tune the car in. :banana: :banana: Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 10, 2003 Share Posted November 10, 2003 what are those specs for? Tourqe? HP? Something in-between? GD Quote Link to comment Share on other sites More sharing options...
WJM Posted November 10, 2003 Author Share Posted November 10, 2003 supposed to be a torque grind. But a 20 HP gain as well. Quote Link to comment Share on other sites More sharing options...
