Behold...the cam specs!
WJM
No. Awaiting CU HGs from CA. I also have much work left before I put the engine back together.
Finnish cleaning heads.
Dissasemble heads.
remove all gaskets and seals from the engine.
Finnish cleaning engine.
Inspect engine.
install NEW gaskets and seals.
reassemble the heads.
Receive CU HGs, and lighten'd flywheel.
install those components.
Install cams.
Install and swap over thingys for the spyder intake to go into a non spyder car.
Take old engine out.
install new engine and swap some more things over.
Run engine.
Burn those rice boys in their boy racer rice cars to the ground.
Oh, and THEN tune the car in.
:banana: :banana: :banana: :banana:
