Front Diff drain Plug Size?
3 replies to this topic
#1 SuBrat84
SuBrat84
    What's REALLY going on???
  • 1,520 posts
  • Tucson
Posted 09 October 2006 - 11:16 PM
I'm kinda doing this for the search engine on here...
What size socket or type of tool do I need to pull the drain plug on the front differential of an auto transmission (AT) ???
I searched a whole bunch and found: Some are 21mm, Some are 22mm, and the new stuff is a Torx. The ONLY thing I could find about it said T70 INTERNAL Torx. Is this correct?
Does the 21/22 differ between MY or is it like a Legacy/Impreza thing?
The car I am specifically trying to find out about is a '99 Legacy L with a 2.2. It is definately a Torx. Internal means it goes into the bolt instead of around the bolt like a normal socket? If yes, then it is Internal. Is T70 the right size? Thanks!
-Eli-
#2 porcupine73
porcupine73
    Obligate carnivore
  • 5,201 posts
  • Buffalo, NY
Posted 10 October 2006 - 07:41 AM
It's likely T70, I found it in this post. I think I just solved my search engine woes, but that's for a different post.
#3 SuBrat84
SuBrat84
  • 1,520 posts
  • Tucson
Posted 10 October 2006 - 06:54 PM
Duh.. I remember that thread now.. I wonder why I couldn't find it in the search engine. I like your idea about the "similar threads" ... when I'm not retarded I do that! :banana:
#4 porcupine73
porcupine73
    Obligate carnivore
  • 5,201 posts
  • Buffalo, NY
Posted 10 October 2006 - 07:41 PM
Well when I first searched for torx, I didn't find that thread, at least not near the top of the list. After I did an advanced search and sorted by relevancy instead of showing most recent posts first it was right near the top. To find that T70 bit might also try searching online for a T70 'torque' bit as I have seen in ads where they put 'torque' instead of Torx. Looks like Lisle makes one.
