Will engine run with timing belt marks off?
7 replies to this topic
#1 david_steverson
david_steverson
    New User
  • PipPip
  • 21 posts
  • Marietta
Posted 18 October 2006 - 04:54 PM
So, I'm replacing timing belts, etc on my '94 Loyale and I just noticed that while I have my flywheel set at the center valve timing mark, the left camshaft sprocket is lined up with mark on belt cover (as it should be) but the right is straight down (180 degrees off).
I did not rotate those cams so it was already that way. Is it even possible for the engine to have run like that???
If the answer is yes, but it will run like crap, that explains a lot!!
Thanks in advance, Dave
#2 81SubieGL
81SubieGL
    New User
  • PipPip
  • 11 posts
  • Bellingham
Posted 18 October 2006 - 05:56 PM
from my experience it will still run, one of my timing belts snapped, and the other one stayed in tact, but the car ran like poo.
#3 Snowman
Snowman
    Midnight Passenger
  • 3,538 posts
  • Haines
Posted 18 October 2006 - 05:58 PM
The cams are supposed to be 180 degrees from each other. If they are both in the same position, it probably wouldn't run (never tried it myself). I know, it's a weird way to set up the timing procedure, but that's the way it is.
If the timing is off by even one tooth, it will run like absolute crap. (Yeah, I've done that before, as it's a pain to see the alignment marks while the engine is in the car.)
#4 Numbchux
Numbchux
    EJ conversion addict
  • 6,827 posts
  • Saginaw, MN
Posted 18 October 2006 - 06:21 PM
as already mentioned, it should be like that. you set the drivers side one straight up, then rotate the crank 360* (cam will only go 180*), and then set the passenger side one straight up.
and if it's off, even by only one tooth, it'll barely run at all....
#5 david_steverson
david_steverson
    New User
  • PipPip
  • 21 posts
  • Marietta
Thanks Snowman, after reading your post and re-reading the manual, I can see what you mean. I'll live in hope that the belts were off a tooth or so and that the car will run better when I'm finished.
The previous owner said he had the belts changed not long ago, but it just did not run right.
Dave
#6 jeffast
jeffast
    f*** im 24
  • 2,029 posts
  • midwestren
Posted 18 October 2006 - 10:10 PM
thats what mine did when the belts were one tooth off
#7 daeron
daeron
    Cunning Linguist
  • 3,600 posts
  • West Palm Beach
Posted 19 October 2006 - 05:49 AM
never hurts to check the distributor timing adjustment with a light when youre done.
#8 bgd73
bgd73
    Banned - WARNING! Disregard EVERYTHING posted by this user
  • Banned
  • 1,210 posts
  • Concrete Glacier
Posted 19 October 2006 - 12:18 PM
they run ok off one tooth. EGR valve does not like it and anything top end or exhaust (whatever side had the leaky opening as a result of one tooth off). If on exhaust side opening too soon, it is ok except for egr, intake open too long, bad news on top end and valves. One way or another you may notice something strange even after fixing. Gas additives that clean are good if something physically didn't get hurt (the valves especially) maybe a gasket challenged, etc. mine recovered even after a long trip with a tooth off and scrapping egr entirely (not necessarily necessary to scap it, i chose to.):)
