ABS light '92 SVX
1 reply to this topic
#1 Guest_TDOG67_*
  • Guests
Posted 04 August 2003 - 08:51 PM
ABS light stays on in the '92 SVX, any suggestions or advice? I am going to be changing the brake pads, suggested pads? Will light go away after changing pads?
#2 Guest_95LEGAWD_*
  • Guests
Posted 04 August 2003 - 10:17 PM
I've got a 95 Leg with the ABS light on-took it to a mech. gave me/him 3 codes for a short on RF, open RR and relay sensor. I doubt if all of these went bad at the same time but I haven't had time to check all the sensors, fuse, etc..
Do the pads and check all the wheel sensors for corrosion, broken parts/wires and the fuse.If it's still on...get the codes read...
I've found a place that sells used ABS sensors, If you want it I'll have to find it in my files....somewhere in the Seattle area
