cruise control
14 replies to this topic
#1 Phil Andrus
Phil Andrus
    New User
  • Pip
  • 1 posts
  • Chimacum, WA
Posted 11 November 2003 - 09:42 PM
Our '94 Legacy came to us without cruise control. Lately, I've been contemplating adding a cruise control system, either a Subaru system from a wrecking yard or an aftermarket system. The only aftermarket supplier I've found is JC Whitney, whose products I generally avoid. I would appreciate any observations or advice regarding the quality of Subaru factory cruise control and the relative ease of installation of the components.
Phil
'94 Legacy of humble origins: manual trans,
2wd, manual windows, no air
conditioning, but, alas, no cruise control.
#2 GLCraig
GLCraig
    Livin' the live
  • 2,706 posts
  • LV, Washington
Posted 12 November 2003 - 01:22 AM
The factory cruise control isn't too difficult to install, It dose require taking the airbag off of the steering wheel though. If you do decide to get one from a wrecking yard, you will need to get one from another 92-94 with the same transmission. Getting a new cruise control kit from a dealer may be a better option since you'll get the installation instructions.
#3 avk
avk
    Certified Subaru Nut
  • 906 posts
  • somerset County, NJ
Posted 12 November 2003 - 08:08 AM
I believe cruise control was available as a kit for 1st gen., like it was for 2d. It may be hard to find now. Try to get the part number first.
#4 (goldfish)
(goldfish)
    USMB Regular
  • PipPipPip
  • 49 posts
  • Mpls
Posted 11 March 2005 - 08:19 PM
I just got a 97 brighton, and was entertaining the idea of adding cc. Does anyone have a complete list or instructions? Thanks
#5 avk
avk
  • 906 posts
Posted 11 March 2005 - 09:39 PM
Instructions come with the kit, they're pretty straightforward. I have an instruction sheet for Impreza but it's not the same.
#6 Handtool
Handtool
    Eat, Live, Breath Subaru
  • 290 posts
  • Yelm
Posted 11 March 2005 - 10:25 PM
The Part # for the Gen 2 legacy is H7010AC000
http://www.1stsubaruparts.com/ the kit lists for 54$
#7 subie94
subie94
    Major Subaru Fanatic..
  • 1,577 posts
  • Hooksett
Posted 11 March 2005 - 11:06 PM
i was told by a friend of mine that you can just remove the steering wheel,you gotta disengage the air bag.something like disconnecting the battery for like 5 mins. does anyone know exactly how to do it??
#8 Tiny Clark
Tiny Clark
  • 807 posts
  • Germany
Posted 12 March 2005 - 08:46 AM
$54 seems really cheap for the control module, cable, steering wheel stick, etc.
But, ya never can tell.
#9 Handtool
Handtool
  • 290 posts
  • Yelm
Posted 12 March 2005 - 01:58 PM
http://cgi.ebay.com/...&category=33595
#10 avk
avk
  • 906 posts
Posted 12 March 2005 - 11:10 PM
The cruise kits are among those obsolete accessories discounted well below cost. There are people who bought and installed them, so it's a real deal.
#11 Tiny Clark
Tiny Clark
  • 807 posts
  • Germany
Posted 13 March 2005 - 12:39 PM
Wow, that's amazingly cheap, but I think it'll take a bit more knowledge than being able to turn a screwdriver in order to get it properly installed.
With decent mechanical abilities, I'm sure it could be done on a weekend with a good supply of a carbonated adult beverage.
#12 Handtool
Handtool
  • 290 posts
  • Yelm
Posted 13 March 2005 - 12:44 PM
I'll let you know next week. I don't forsee any problems, the instructions are detailed and seem pretty straight forward.
#13 Handtool
Handtool
  • 290 posts
  • Yelm
Posted 22 March 2005 - 04:46 PM
Well, I just finished installing the factory cruise kit on my '95 Legacy sedan MT. It was pretty easy. The hardest part was fitting the control unit up behind the glove box and working under the dash putting in the safety switches. You will need a T30 security torx (the one with a hole in the center) bit to remove the air bag. They are torqued down so I, put the bit into a 1/4" socket to break it free. Otherwise just basic tools are needed. Had it in and tested in just under two hours. Definatley a worthwhile upgrade.
-Handtool
#14 Tiny Clark
Tiny Clark
  • 807 posts
  • Germany
Posted 23 March 2005 - 01:54 AM
Cool, glad you got it done so quickly. Was the throttle already set up for the cable?
#15 Handtool
Handtool
  • 290 posts
  • Yelm
Posted 23 March 2005 - 11:23 AM
Yep, everything is there. The cable for the cruise runs and mounts right along the accelerator cable. Just adjust it so there is no slack and it's not opening the throttle. For $50 it can't be beat.
