EA82 Stant Superstat Thermostat
8 replies to this topic
#1 DasWaff
DasWaff
    USMB Regular
  • PipPipPip
  • 83 posts
  • Durham
Posted 28 October 2006 - 08:32 PM
Hey all, this post is for those of you, like myself, that have to deal with completely proprietary auto parts stores such as Advance Auto. They cannot quickly (or accurately) convert part #'s into bin #'s or sku's :confused: . SO... the Stant part # for the 180 degree F Superstat thermostat is 45858, but if they are compelled to look up parts by year and model and it doesn't show up under your EA82 Subaru it is also the thermostat for the 1987 Nissan Pulsar SE. Just an FYI for those who care... DW
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,694 posts
  • Portland
Posted 28 October 2006 - 09:51 PM
Any thermostat for a small block chevy will work - same size, and you can get them in any temp you could want. I like a 180 or 190, but some people prefer the 170 in turbo's and such.
#3 jeffast
jeffast
    f*** im 24
  • 2,029 posts
  • midwestren
Posted 28 October 2006 - 10:07 PM
thanks dw and gd good to know
#4 subiemech85
subiemech85
    SIX STAR SERVICE
  • 2,710 posts
  • down by the river
Posted 30 October 2006 - 11:07 PM
the problem with a "GM" type thermostat is that it does NOT have the jiggle pin, which is an absolute must have
if in a pinch, you can drill a 1/8" hole
#5 Snowman
Snowman
    Midnight Passenger
  • 3,538 posts
  • Haines
Posted 30 October 2006 - 11:14 PM
Wow, that's bizarre. I wonder if it's coincidence, or if the super-human 80's Subaru engineers planned that?:rolleyes:
Good point about the drilling, Subiemech. I've done that in the past too. Just drill a small hole, and the air will get through no problem, but it won't allow so much coolant as to over-cool the engine.
#6 GeneralDisorder
GeneralDisorder
  • 21,694 posts
  • Portland
Posted 30 October 2006 - 11:36 PM
Yeah - a small hole solves that problem, and is a minor inconvience for someone looking for a special temp other than stock.
Turns out that 54mm is almost exactly 2 1/8" (2.125"), which is the size of the GM stuff.
#7 Virrdog
Virrdog
    Subaru Nut
  • 590 posts
  • NE Ohio
Posted 31 October 2006 - 01:13 PM
That's good to know. 2.125" is close enough to 2.125984" (54mm) for me. :brow:
#8 jacobs
jacobs
    USMB is life!
  • 198 posts
  • IS, Colorado
Posted 31 October 2006 - 01:54 PM
Why is the "jiggle pin" a must have? I've used 160E unmodified GM thermostats in the summer for the last 15 years without any ill effects. The reason I change to the lower temp in the summer is it eliminates the hot soak carb problems.
#9 NoahDL88
NoahDL88
    Elite Master of Cookies
  • 4,271 posts
  • Everett, WA, USA
Posted 31 October 2006 - 02:09 PM
The jiggle pin, and the drilled hole in its stead, is to help get the air out of the system, as air pockets are bad for cooling and can produce localized hot spots.
