Getting a fuel odor from my 91 Legacy on warm days. It's noticeable while driving with the vent fan running, and also noticeable outside the car after it's been parked for a few minutes. No obvious fuel leaks.
Per the service manual, I checked the evaporation line to the canister by unplugging it from the canister and verifying that it is unobstructed by blowing air through it. Also disconnected the purge hose and verified that the purge control solenoid valve will not pass air.
There is a third hose on the canister that is not shown in the service manual--it comes from the bottom of the canister and appears to be an overflow hose in case the canister becomes saturated. I'm pretty sure the fuel smell is originating from this hose.
Would replacing the canister help? Do they "wear out" over time? I'm assuming the purge control solenoid valve is Ok since it does not pass air and I'm getting no check engine light.
Thanks for any inputs,
Herb
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Fuel Odor 91 Legacy/ Evaporative Canister
Started by
Guest_herbob_*
, Jul 28 2003 02:46 PM
7 replies to this topic
#1
Guest_herbob_*
Posted 28 July 2003 - 02:46 PM
#2
Guest_ccrinc_*
Posted 28 July 2003 - 09:51 PM
On hot days, the charcoal canister simply cannot handle all the fumes that come from the gasoline.
One temporary help is to vent your gas tank (open the gas cap for just a couple of seconds).
Don't overfill the tank. Run about 3/4 full unless you're on a road trip.
Heck, one day when it was about 100F here, mine even was doing it with about half a tank! <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/grin.gif ALT=" >D">
Emily
www.ccrengines.com
Emily
www.ccrengines.com
#3
Guest_Setright_*
Posted 29 July 2003 - 12:29 AM
Mine also has a faint trace of fuel smell, most obvious near the filler flap. Only in summer, though.
I think the only way to get rid of it is to replace ALL the hoses and the canister. The hoses age and start to develop tiny cracks that petrol molecules can pass through, and surely the carbon element in the canister has a limited life.
Worth the cost?? I don't think so. The human nose isn't all that insensitive and even tiny amounts of fuel in the air will register as smell.
However, I would not be happy with a fuel smell in the cabin. Perhaps you could get away with replacing the hoses in the engine compartment?
Oh, and heaven forbid: You MIGHT have a tiny hole in the fuel tank. Friend of mine has a Mercedes and we had to replace his fuel tank because of similar symptoms. The hole wasn't visible, but the leak left a dark patch on the outside of the tank and the cabin stank when on the move with the windows down!
But hey, Legacies have a protective plastic cover on the leading edge of the tank, so this is unlikely.
#4
Guest_canajun2eh_*
Posted 29 July 2003 - 06:48 PM
Check the purge solenoid valve. Apply 12 volts to the solenoid, and try to blow through the hose.
The purge valve is supposed to open when the engine is at operating temperature and running at faster than idle. The engine vacuum will draw the accumulated vapours out of the canister, to be burned by the engine. This assumes that the hose on the other side of the valve is properly connected to the intake manifold.
If the purge valve is stuck closed, the engine computer can't diagnose the problem. If it's stuck open, the engine won't idle properly.
#5
Guest_herbob_*
Posted 29 July 2003 - 10:18 PM
Emily, Setright, and Gerry,
Thanks very much for your inputs.
I will check the purge valve, Gerry, and post back with the results (and if defective, verify whether replacing the valve solves the odor problem).
Thanks again,
Herb
Thanks again,
Herb
#6
Guest_herbob_*
Posted 01 August 2003 - 09:56 PM
Here's an update.
Checked the purge solenoid valve by hooking a vacuum gage to the line when the engine was warm. It's drawing vacuum of about 4 in Hg at 4000 revs and I figured this was plenty to pull fresh air thru the canister.
Went ahead and replaced the canister today. Will post back after some hot days to note if this actually solved the problem. Stay tuned.
Herb
Herb
#7
Guest_wraithrslib_*
Posted 01 August 2003 - 10:15 PM
yeah just open your fuel cap for a minute cheers.
#8
Guest_herbob_*
Posted 04 August 2003 - 08:46 AM
We've had a couple of hot days now and no fuel smell--the new canister seems to have solved the problem (NAPA had one, cost me $75. Said it was the last one in stock in this area).
Think the activated carbon in the canister eventually becomes saturated. In other words, it stores the hydrocarbons and then releases them as fresh air is drawn across the carbon when the purge valve is open. But it likely always retains just a bit of hydrocarbon each time, and eventually becomes saturated.
Maybe I was lucky and didn't have the minute fuel leaks from old fuel hoses. I didn't go with the "loosen the fuel cap" approach because I was getting fuel odor in the cabin even when stopped at a stop light.
Thanks again for all the inputs.
Herb
Herb
