newsoobdude Posted November 3, 2006 Share Posted November 3, 2006 I am going to go about lifting my 83 GL Wagon atleast 6 inches but no more than 8. I'm wondering what mods besides the steering shaft lengthening I have to do to my steering. Will just lengthening the shaft work? Quote Link to comment Share on other sites More sharing options...
Phizinza Posted November 3, 2006 Share Posted November 3, 2006 Are you going to be using a T-case? (I don't think that makes any difference to the question though) Quote Link to comment Share on other sites More sharing options...
newsoobdude Posted November 3, 2006 Author Share Posted November 3, 2006 Are you going to be using a T-case? (I don't think that makes any difference to the question though) No, I will do that later when I have more cash. Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted November 3, 2006 Share Posted November 3, 2006 Should be able to lengthen the shaft like on the 3 inch lift from PK, you will also need to extend the brake lines, and a few other wires and hoses to make everything work. Quote Link to comment Share on other sites More sharing options...
Phizinza Posted November 4, 2006 Share Posted November 4, 2006 Radiator pipes wouldn't line up would they? Heater pipes may need work? I'm not really helping here am I Quote Link to comment Share on other sites More sharing options...
scrap487 Posted November 4, 2006 Share Posted November 4, 2006 Radiator pipes wouldn't line up would they? Heater pipes may need work? I'm not really helping here am I . Radiator lines will need some work, I found I could just modify the lower one but the top one I replace with some of the flexible heater hose stuff. as far as hoses to the heater core go I dont remember having to replace those. Steering shaft and brakelines are the big things, along with rear shocks and I'm sure you know you need strut top extensions or something for similar effect to gain any lift... they will need to be offset to regain correct camber. You will need to play with/modify the shifter and 4wd linkages significantly. Quote Link to comment Share on other sites More sharing options...
monstaru Posted November 8, 2006 Share Posted November 8, 2006 old school tie rod.cut steering shaft,place into ends of desired length of tie rod....weld. it helps if you use a piece of angle iron to keep stuff squared up.... with that angle you will probably have to grind a bit off of the end of your steering column so it doesn't rub horribly. Quote Link to comment Share on other sites More sharing options...
