So.... what could cause the front calipers to stick? (89 GL wagon). After driving today, both front rotors are quite hot -- not glowing, but way too hot to touch. And I haven't been using the brakes, except obviously to stop the car when I get out to feel them. And the gas mileage dropped from 30 to around 23 for this tank. And today on the freeway, it suddenly started jerking -- as if I had a fluid soaked drum brake grabbing on the right front. I disconnected the hillholder, so it's not that. Will rebuilding my calipers help with this? Or is there some trick with the pads or mounting the calipers? I'ver ordered new pads and caliper rebuilt kits, already, but wondering if I should get anything else.
Thanks
Z
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
sticking front brake calipers
Started by
zyewdall
, Nov 16 2006 11:18 PM
6 replies to this topic
#1
Posted 16 November 2006 - 11:18 PM
#2
Posted 16 November 2006 - 11:27 PM
Hey, once you enter a new thread, all of a sudden you get a bunch of relevant old threads, that didn't seem to come up from a search... Anway, it seems like the consensus is rebuild the calipers, and make sure all the rust is off of the slide pins for the calipers and the mounting points for the pads... But if anyone still wants to chip in, feel welcome.
Z
Z
#3
Posted 17 November 2006 - 03:37 AM
Ive had that problem on my brat , i simply replaced pads took away the rust from the sliding points. Then bleeded the brakes and got myself a pair of working frontbrakes.
#4
Posted 17 November 2006 - 10:42 AM
Thanks
Z
If you find the calipers and all to be working as designed, high on the list is old/swollen internally, rubber brake lines.
HTH
Doug
#5
Posted 17 November 2006 - 11:18 AM
i think the emergency brake is on the front just like in an XT6. if this is the case i'd suspect the e-brake to be sticky since both are hot. i find it unlikely or very uncanny that both front calipers would start sticking at the same time with nothing in common other than age.
grabbing the e-brake lever on the caliper and moving it back and forth a few times will free a sticking e-brake, a very nice thing to know since it's an easy fix in a parking lot somewhere. on an XT6 i'm almost positive this can even be done without removing the wheel.
they are super easy to rebuild. new oring around the piston and a new boot with circlip and you're done. if you haven't done one before i recommend doing them one at a time, that way you can see how the boot and circlip is installed on the second one while you reassembled the first. it's very straight forward, but nice to see exactly how it goes together if you haven't done it before. and of course grease the e-brake mechanism and the slides.
#6
Posted 18 November 2006 - 09:17 PM
Did this problem just come out of the blue, or was it after replacing the pads? If after replacing the pads, then I would suspect issues with the pistons not being aligned so its grooves match the pads pins. Otherwise, follow GG's suggestions.
#7
Posted 18 November 2006 - 11:05 PM
don't forget to check the parking brake cable too. i suspected my calipers after changing them after one set of pads fried up, when i went to replaced them i found that its my cables or the mechanism in the car thats at fault and not the calipers.
btw mines an 86' GL wagon, incase you wanted to know.
