Lift time, finally?
21 replies to this topic
#1 BruceyWV
BruceyWV
    Subaru Fanatic!
  • 360 posts
  • 39.658193 -79.964263
Posted 17 November 2006 - 12:48 AM
Feedback welcome. I've got a 2000 Outback and just take it on the trails in my county for fun, nothing too extreme. But all the trails in my county are uneven and I basically can't decided to do a strut spacer or a king spring lift.
Its currently running 27" SSR's and I havent gotten it stuck once (I'm awful slow and cautious though).
Springs: I like how the king springs raise the entire vehicle up, I wont mind putting some extra wear in the cvs, but travel seems like it would be limited and I dont have nearly enough travel already.
Strut spacers. Where can I get strut spacers only? If I can get a good deal on them, I think that is what I'll do. Same travel and gain an inch or two. Although at the same time, I need to replace my struts soon too. They're pretty much shot.
#2 quazar
quazar
    USMB Regular
  • PipPipPip
  • 62 posts
  • Atlanta
Posted 17 November 2006 - 01:51 AM
brucey... do both! is the H6 in yet?
#3 BruceyWV
BruceyWV
    Subaru Fanatic!
  • 360 posts
Posted 17 November 2006 - 02:44 AM
H6 isnt in, I have the radiator, and accessories for it. But basically I ran out of time needing my own car, and am using the money left over from it and putting it into a lift. Gotta have my fun ya know.
#4 Numbchux
Numbchux
    EJ conversion addict
  • 6,813 posts
  • Saginaw, MN
Posted 17 November 2006 - 09:32 AM
I would suspect that the lift springs would limit travel, just like cranking up the adjustable suspension on EA cars.
you could probably have some strut extensions made....but they'd have to be custom.
#5 BruceyWV
BruceyWV
    Subaru Fanatic!
  • 360 posts
Posted 23 November 2006 - 08:46 AM
So thats about my only choices? Dang it. I was hoping for some magic.
#6 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 4,045 posts
  • Bellingham
Posted 23 November 2006 - 10:10 AM
front strut towers what maybe 2" I could make a set
#7 Numbchux
Numbchux
  • 6,813 posts
  • Saginaw, MN
Posted 23 November 2006 - 11:57 PM
rear ones are pretty similar. I bet you could make a set of those pretty easy too...
they still wouldn't solve the spring perch clearance problem....
#8 BruceyWV
BruceyWV
    Subaru Fanatic!
  • 360 posts
Posted 24 November 2006 - 01:03 AM
Are we talking about putting a spacer on the strut, to drop it from the body, or extending the strut itself inside the coil spring? I'd be happy with either, but if I was going to do the latter some lift springs would definately be in order. Hmmm.
#9 Numbchux
Numbchux
  • 6,813 posts
  • Saginaw, MN
Posted 24 November 2006 - 11:29 AM
he's talking about a block between the top of the strut, and the strut tower on the car. just like the EA ones.
#10 BruceyWV
BruceyWV
    Subaru Fanatic!
  • 360 posts
Posted 24 November 2006 - 01:20 PM
Sounds like a plan to me.
LOL I love lifting unibody's.
Still interested Scott?
#11 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 4,045 posts
  • Bellingham
Posted 24 November 2006 - 01:37 PM
if its the same as a 91 legacey i have the struts to make the pattern off,
#12 BruceyWV
BruceyWV
    Subaru Fanatic!
  • 360 posts
Posted 25 November 2006 - 02:12 AM
I can just get you a new pair of struts, since I'll be replacing mine regardless. The only thing I cant decide on is putting on stiffer springs too.
#13 Numbchux
Numbchux
  • 6,813 posts
  • Saginaw, MN
Posted 25 November 2006 - 05:50 AM
the strut tower pattern will be the same. not sure of the offset required to avoid camber problems (although there is some adjustment at the knuckle). but it looks like the strut tops are at an angle....
#14 offroadsubaruguy
offroadsubaruguy
    Subaru Nut
  • 729 posts
  • arvada, colorado
Posted 28 November 2006 - 09:16 AM
the rears will be different i believe... at least mine are.. the rears are narrower at the top.... just double check first.....
#15 s'ko
s'ko
    RIP
  • 1,722 posts
  • Los Angeles
Posted 28 November 2006 - 11:14 AM
if you are gonna replace your struts, try sourcing a set of forester struts/springs from Nasioc or I-club.
Some Forester owners lower their rides w/STI/WRX stuff and usually have their old struts lying around.
Got a set for Forester XT struts w/5k miles on them for $250.00.
BW
#16 BruceyWV
BruceyWV
    Subaru Fanatic!
  • 360 posts
Posted 28 November 2006 - 11:48 AM
:confused:
Arent mine taller than a forester's begin with?
#17 Numbchux
Numbchux
  • 6,813 posts
  • Saginaw, MN
Posted 28 November 2006 - 02:22 PM
:confused:
not taller, but similar....it certainly wouldn't be an upgrade
and yes, the rear strut top is different than the front, but very similar. the older gen ones are COMPLETELY different....
#18 BruceyWV
BruceyWV
    Subaru Fanatic!
  • 360 posts
Posted 28 November 2006 - 03:59 PM
So, would scott just need the strut tops to make a set of spacers for them, or the entire thing?
I figure while I'm in there, I'll replace the whole unit, struts/springs/mounts and sell the old ones, I'm sure someone around here would want them, at least for the springs. The strut tops arent going to add too awful much to the price.
#19 s'ko
s'ko
    RIP
  • 1,722 posts
  • Los Angeles
Posted 28 November 2006 - 05:27 PM
:confused:
:cool:Ahh, you have an Outback.
BTW I got Forester XT struts which are a tab bit taller.
BW
#20 BruceyWV
BruceyWV
    Subaru Fanatic!
  • 360 posts
Posted 28 November 2006 - 06:17 PM
Well, this answered my questions:
http://www.ultimates...r outback strut
The Outbacks (what I already got) seem to be the tallest.
#21 dome24
dome24
    USMB Regular
  • PipPipPip
  • 100 posts
  • Anchorage
Posted 30 November 2006 - 11:59 PM
Something like this? www.cornfedsuspension.com A lot of Tacoma wheelers run this type of lift, i chose to just use OME Landcrusier struts and springs on my Taco, and Forrester springs Legacy struts on my Imp Coupe.
Pete
"Keep the rubber side down"
:burnout::burnout:
:burnout::burnout:
#22 BruceyWV
BruceyWV
    Subaru Fanatic!
  • 360 posts
Posted 01 December 2006 - 10:27 AM
yup, and that price is much more acceptable than the 2 inch body lift for 900$ + shipping at renick.
