87 GL-10 Turbo AT Rear end falls when...
1 reply to this topic
#1 KRMusher
    New User
  • Pip
  • 4 posts
  • Lafayette
Posted 20 November 2006 - 03:16 PM
Rear end air bag struts (both) fall over night BUT: last night I put on the raise height switch and they didn't fall! What's going on here??
If I have to replace can you change one end only (rear) over to just springs, as in some posts, or do you need struts?
Or do you have to change all 4 if you are converting to non air set up?
Any info appreciated!! Only has 84k miles!
#2 calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 20 November 2006 - 05:54 PM
Change all four and get it over with. Air ride is a pain in the ass when it gets to be 20 years old, but then again, many things are a pain in the ass when they're 20 :)
Just get four Junkyard strut/spring combos from the wrecking yard and slap them in there. Easy.
Mine was converted from air ride to standard struts, then to XT6 parts, then to XT6/legacy mix with adjustable coilovers. About to go 100% Impreza/Legacy stuff
