Whats up with my heater/blower and how do I fix it?
11 replies to this topic
#1 Subarutex
Subarutex
    Oldschool Show Queen
  • Moderator
  • 2,551 posts
  • Mountlake Terrace
Posted 24 November 2006 - 04:26 PM
Ok, in my '87 RX my heater only blows on setting 3.
How do I got about fixing this? Will it require just a new blower motor? Or something else?
I'm compleltely lost when it comes to interior things. I can certainly blow motors up though!
#2 Ross
Ross
    Can't be bothered
  • 1,865 posts
  • Christchurch, New Zealand
Posted 24 November 2006 - 05:07 PM
Most likely its just a wee resistor bank thingee which sticks in the side of the heater box. Not sure about the exact location on ea82 cars, but its a small square bit about 20mm square if I remember correctly. It has wires plugged into it, and when you pull it out its got open resistive wire coils sticking out of it.
So yeah, its a square thig with wires coming out of it, does tha narrow it down? :rolleyes:
#3 WoodsWagon
WoodsWagon
    Formerly 91Loyale
  • 4,100 posts
  • NH
Posted 24 November 2006 - 05:29 PM
one of the bolts that holds in the blower motor holds in this blsck box thingy that also has two more screws holding it in. This is the resistor block. The coils often break.
#4 idosubaru
idosubaru
    Elite Master of the Subaru
  • 23,755 posts
  • East Coast
Posted 24 November 2006 - 05:40 PM
the control/switch could be bad as well. i had the same thing about a year ago and replaced the resistor block, didn't help. replacing the control switch fixed it.
#5 Subarutex
Subarutex
  • Moderator
  • 2,551 posts
  • Mountlake Terrace
Posted 24 November 2006 - 07:16 PM
Define "control Switch"
#6 heartless
heartless
    Do YOU Subaru?
  • 3,293 posts
  • North Central Wisconsin
Posted 24 November 2006 - 07:27 PM
control switch: the knob that you turn for the different speeds...
#7 idosubaru
idosubaru
  • 23,755 posts
  • East Coast
Posted 24 November 2006 - 10:21 PM
control switch...the XT's have a strange sliding mechanism, i was sure other EA82 stuff would be different so i wasn't sure what to call it since i didn't know exactly how it works. but he's right...whatever you use to vary the speeds. that actual button/switch you touch to change it. the contacts in it could be bad. depending on how yours is constructed (again i'm an XT nut), you can test it or look for bad contacts inside it.
#8 Numbchux
Numbchux
    EJ conversion addict
  • 6,830 posts
  • Saginaw, MN
Posted 25 November 2006 - 05:04 PM
the #4 setting doesn't use a resistor. so if this one doesn't work, I would suspect the switch, or wiring, before the resistor pack. my #1 & 2 resistors are blown, so I only have 3 & 4....
but yes, the resistor pack is right next to the blower under/behind the glove box. yes, you'll probably have to contort your body half way under the dash to get at it...another reason to try the switch first. in fact, I'd pull the switch apart and make sure all the contacts are good and clean, and see where that lands you. maybe even get out a multimeter and make sure you're getting continuity through the right wires on all the settings.
#9 idosubaru
idosubaru
  • 23,755 posts
  • East Coast
Posted 25 November 2006 - 06:12 PM
if you're down there with the resistors pull out the blower fan squirrel cage and make sure it's all cleaned out. they often have bits of insulation or other unwelcome pieces of junk in them. makes it quieter and will work better. of course if yours is perfect that no need.
#10 NoahDL88
NoahDL88
    Elite Master of Cookies
  • 4,271 posts
  • Everett, WA, USA
Posted 26 November 2006 - 02:13 AM
Next time we go yarding for parts, i'll help you get the resistor out of the blower motor, to see if thats what it is. There cheap, and they blow out pretty regularly anyway, so if its not it at least we'll have a spare. We need to go anyway, i need rust free EA-81 bits, and i'm sure i need more parts than i can remember.
#11 Bucky92
Bucky92
    Drive Fast, Take Chances
  • 3,664 posts
  • New Milford
Posted 26 November 2006 - 07:16 AM
I only have 1 and 3 on Bucky..but I have another switch just havent got around to putting it in...has been that way for 3 years;)
#12 Prospeeder
Prospeeder
    Subaru Fanatic!
  • 487 posts
Posted 26 November 2006 - 01:26 PM
yea if #1 works but 2 doesnt, its not the resitor, cause i belive they go in sequence, when i took mine out, #2 was wasted, but the #1 was fine, but speeds 1 and 2 didnt work, i got another one from an old, half torn apart, moldy, moss filled water soaked GL wagon and it works great, lol.
