Where can I buy a Hitachi distributor for a Brat?
16 replies to this topic
#1 apparition13
apparition13
    New User
  • PipPip
  • 11 posts
Posted 30 November 2006 - 02:21 PM
Follow up to this thread;
It's the distributor. The tach been doing more of the dancing around. I tried to get one through ebay, but it doesn't have the same housing. Anyone know where I can get a Hitachi ditributor for an '86 Brat? Anyone know where I can find a catalogue of part numbers for said Brat? Or even someone who carries Brat parts, and is easy to deal with?
thanks,
P.S. fwiw, the distributor in my Brat has these numbers on it:
4298787 00, D4R88-12 6503, and the one I ordered has these: 22100 AA 121
D4R84-52 6701. It has an extra flange on it. Could I remove the flange and use the ditributor? Anyone know?
apparition13
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 20,278 posts
  • Portland
Posted 30 November 2006 - 02:37 PM
P.S. fwiw, the distributor in my Brat has these numbers on it:4298787 00, D4R88-12 6503, and the one I ordered has these: 22100 AA 121
apparition13
The two-flange distributor is for an EA82. It does not have the right drive gear, but assuming it's for a carb engine, then yes. You could cut the flange off, move the wireing harness a bit, enlarge the adjuster slot on the other flange, change the drive gear (hole must be redrilled higher up on the shaft), and it would work.
Call these guys. I've worked with them on many occasions and they do excelent work. Your distributor needs new shaft bushings, and probably will need the vacuum advance rebuilt. They can make your unit as good as new for about $50 - $75:
www.philbingroup.com
They can also source new units for you, but the price is astronomical - probably in the $200 - $300 range.
If you are willing to spend a little more (than the rebuild - probably be about the same as a new distributor for everything), and upgrade in the process, then the Single Point Fuel Injection would be the far better alternative - the SPFI uses it's own distributor, and you can get one and have philbin just swap the drive gear from your Hitachi over to it. The SPFI disty uses easily replaced pin bearings for it's shaft (and they last like 300,000 miles anyway) so no worries about this ever re-occuring. Read my full write up on the SPFI swap here:
http://home.comcast..../EA81_SPFI.html
#3 apparition13
apparition13
    New User
  • PipPip
  • 11 posts
Posted 30 November 2006 - 02:47 PM
My plan was to install this one, and send the old one off to be rebuilt. Unfortunately, I need the car and can't have it sit while I send the ditributor off. The SPFI swap sounds great, but I'd have to have it done, since I'm not much of a mechanic, and I fear the labour cost may prove prohibitive.
#4 GeneralDisorder
GeneralDisorder
  • 20,278 posts
  • Portland
Posted 30 November 2006 - 02:49 PM
Ask in the wanted forum for a used one - there's members here with BIG parts collections. Then use that while you send the other one away for rebuild.
#5 GeneralDisorder
GeneralDisorder
  • 20,278 posts
  • Portland
Posted 30 November 2006 - 02:51 PM
Oh - and if you are enough of a mechanic that you can replace a disty, then you could do the SPFI swap. It's not that difficult.
#6 squatty
squatty
    New User
  • PipPip
  • 29 posts
  • Portland
Posted 01 December 2006 - 05:08 AM
I may be in a similar situation. Looking for a distributor for a 1992 Loyale.
CEL keeps coming on and at one time the code said crank angle sensor but haven't checked the code in awhile...
#7 GeneralDisorder
GeneralDisorder
  • 20,278 posts
  • Portland
Posted 01 December 2006 - 05:52 AM
You are in Portland - land of the Subaru. Head over to Foster U-Pull-It and grab one for $25.
#8 chef_tim
chef_tim
    Romans 5:8
  • 4,780 posts
  • Renner, SD
Posted 01 December 2006 - 07:00 AM
If you have a bit of money to spend give CCR a call and ask them if Kerry is still rebuilding them. Like GD said, "You are in Portland - land of the Subaru. Head over to Foster U-Pull-It and grab one for $25." That would definately be your best bett. If NE is anything like SD stuff is hard to come by in the yards and exspensive too. just a thought, Tim
#9 edrach
edrach
    Charter member OFRT
  • 12,303 posts
  • Bothell, WA
Posted 01 December 2006 - 08:05 AM
Sadly, Kerry is out of business. I'm with GD on Philbin.
#10 squatty
squatty
    New User
  • PipPip
  • 29 posts
  • Portland
Posted 02 December 2006 - 02:14 AM
Guess I'll have to start looking in the yellow pages and online, I know not this Foster u pull, CCR or GD...
#11 GeneralDisorder
GeneralDisorder
  • 20,278 posts
  • Portland
Posted 02 December 2006 - 02:25 AM
GD - that's me :rolleyes:.
You know Foster Ave.? It's in SE Portland. There's a Foster exit off 205. You go east about 1 mile and Foster Auto Parts and Foster U-Pull-It are on the left.
#12 jonas
jonas
    Subaru Nut
  • 766 posts
  • Oakridge
Posted 02 December 2006 - 10:33 AM
exit 17.
#13 squatty
squatty
    New User
  • PipPip
  • 29 posts
  • Portland
Posted 05 December 2006 - 12:21 AM
Thank you everyone...
#14 apparition13
apparition13
    New User
  • PipPip
  • 11 posts
Posted 06 December 2006 - 08:09 PM
thanks, that seems to be working so far.
#15 GeneralDisorder
GeneralDisorder
  • 20,278 posts
  • Portland
Posted 06 December 2006 - 08:12 PM
You modified an EA82 carb disty for your EA81?!?!
Cool - I just didn't expect you would actually DO it. I've done it with SPFI disty's and the process is the same, and theoretically it should work as stock. Glad you got it fixed anyway.
#16 Petersubaru
Petersubaru
    1000+ Super USER!
  • 1,075 posts
  • Sarnia Canada
Posted 06 December 2006 - 08:27 PM
advance auto parts have dissys for the subarus
thanks,
apparition13
#17 brat86
brat86
    USMB Regular
  • PipPipPip
  • 36 posts
  • Gainesville Florida
Posted 13 December 2006 - 09:05 PM
I have an ea-81 disty that I rebuilt, used for 3 months, then blew a freeze plug in cyl head. Brat has ea-82 now. Tossed engine, kept distrib and few other parts. Let me know if you want it.
