Differences in pre 1987 EA82T and post 1987 EA82T
16 replies to this topic
#1 Alex GL-10
Alex GL-10
    USMB is life!
  • 178 posts
  • Catawba
Posted 30 November 2006 - 09:24 PM
What are the differences in the two. I know the MAF sensor changed and I read somewhere that pre 87' had gen 1 heads. What are other differences?
#2 jeffast
jeffast
    f*** im 24
  • 2,029 posts
  • midwestren
Posted 30 November 2006 - 09:30 PM
87.5 xt turbo's got the spider intake and like 30 more hp, a little off topic but it's what i know for certian
#3 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 30 November 2006 - 09:54 PM
Don't think they got any extra power. Definitely not 30.. Maybe 3-4 because of better flow, but otherwise everything is the same as the non spider motors (injectors, fuel pump, boost levels and such)
#4 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,157 posts
  • Oregon City
Posted 30 November 2006 - 10:17 PM
no real power differences (maybe like 1-2 hp), MAF is different, disty, and a few bolt on stuff. Yes, pre '87 had gen 1 heads for sure, most of them up to '88 did when they started using gen 2 heads and gen 3 heads, are mainly current NOS and replacements for cars under warranty back in the day (like '90). Cams were also different I believe and there's something else I think is different but I cannot remember. Blocks are all the same, heads are the same, cam cases and covers are the same, intakes I believe are the same and so is the exhaust and the turbo as well.
#5 Alex GL-10
Alex GL-10
    USMB is life!
  • 178 posts
  • Catawba
Posted 30 November 2006 - 10:32 PM
I knew the MAF sensors were different, but what makes them different? I'm assuming that most parts are interchangable between to two?
#6 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,690 posts
  • Portland
Posted 30 November 2006 - 10:36 PM
The MAF's are completely different (as in different theory of operation - one uses a hot wire, and the other a flapper door), as are the distributors, so the ECU, and the parts of the wireing harness used for those components are too. Most other parts probably would interchange fine.
#7 RenaissanceMan
RenaissanceMan
    Why am I here?
  • 706 posts
  • Eugene, OR
Posted 01 December 2006 - 12:39 AM
PRE 87 injection was gang fire, where as post 87 injection with the optical distributor is sequential injection. Better for fuel economy and emissions fo sho...
(pretty sure, but I'll have to recheck my wiring diagrams to make sure)
-Mike
#8 mikeshoup
mikeshoup
  • 2,196 posts
  • Edgewater, CO
Posted 01 December 2006 - 12:43 AM
Nope. Sequential injection is impossible without a cam position sensor. No MPFI EAs have sequential injection. Its all batch fired.
#9 mikeshoup
mikeshoup
  • 2,196 posts
  • Edgewater, CO
Posted 01 December 2006 - 01:17 AM
I got curious about this, so I went and compared the 86 FSM to the 88 FSM.
The differences I noticed:
MAF - Old system is flapper, new is hot-wire
Distributor - Old system is hall effect w/ vac advance, new is optical, timing controlled by ECU
Knock Sensor - Old system has two wire, new has one
TPS - Old system TPS just has an Idle switch, and fully open switch. New has an extra potentiometer to determine throttle position
WGDS - Old system the wastegate is a direct hookup. New has a solenoid that slightly controls boost. I think its an altitude compensation thing.
Pressure Switch - Old system has one and uses it as a fuel cutoff. New one doesn't, and uses the MAF signal to determine fuel cutoff.
Everything else seemed to look like it worked the same. SO, theoretically one could swap those parts on to their 85-86 and the ECU, and you could gain a small amount.
#10 Alex GL-10
Alex GL-10
    USMB is life!
  • 178 posts
  • Catawba
Posted 01 December 2006 - 01:26 AM
Thats what I was looking at. The biggest thing would be cuting the connecters for the ECU off the newer wire harness and putting them on the older wire harness because they don't plug into the same places.
#11 mikeshoup
mikeshoup
  • 2,196 posts
  • Edgewater, CO
Posted 01 December 2006 - 01:33 AM
Might be easier to just swap engine wiring harnesses...
I actually thought about doing this to the EA81T with how rare they are and difficult to find parts. The EA81T intake has almost nearly an identical sensor system as the pre-87 EA82T.
#12 nkx
nkx
    Rallycross Junkie
  • 891 posts
  • Carlisle, PA
Posted 01 December 2006 - 01:54 AM
by different do you mean better, or just different due to different dimensions and/or tolerances in the head and cam tower?
#13 mikeshoup
mikeshoup
  • 2,196 posts
  • Edgewater, CO
Posted 01 December 2006 - 02:18 AM
Actually, the cams are different. I had posted somewhere before the different duration.
The later cams are probably actually better. The early cams are the same as the carb cams. Though I think the difference is minimal.
#14 joostvdw
joostvdw
    Subaru Nut
  • 609 posts
  • Holland
Posted 01 December 2006 - 06:59 AM
you said the pre87 models had a direct waste gate control and 87+ had a boost solinoid? well, I have a '88 XT with spider and hotwire, but without a boost solinoid? :confused: how can this be? perhaps because it a euro? (yet another difference to add to the list)
#15 calebz
calebz
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 01 December 2006 - 11:50 AM
Correct.. the euro model EA82 runs on a different set of rules than USDM.
IIRC, the EDM models came out at 136hp
#16 PoorManzImpreza
PoorManzImpreza
    Subaru Nut
  • 546 posts
  • BARBADOS
Posted 01 December 2006 - 08:55 PM
...and a factory oil cooler (P/Ns 21315AA001, 21319AA001, 21317AA001, 806959010, 806923020, 45711GA021[sedan/wagon/3d], 45711GA030[XT], hmm this list is longer than I thought.. lol I should just scan the part page)....and a different crank shaft P/N 12201AA030
#17 Alex GL-10
Alex GL-10
    USMB is life!
  • 178 posts
  • Catawba
Posted 07 December 2006 - 12:42 AM
Can you tell any difference in power between the two? (pre 87' and after 87') Does one take power mods better then the other?
