burtonsnowman Posted December 1, 2006 Share Posted December 1, 2006 1992 Legacy. It's got plenty of gasoline, it turns over...but it don't fire up. It's got new plugs and a healthy battery. ???????????? Flywheel? Starter? eh? HELP! Quote Link to comment Share on other sites More sharing options...
backwoodsboy Posted December 1, 2006 Share Posted December 1, 2006 Timing belt? Quote Link to comment Share on other sites More sharing options...
burtonsnowman Posted December 1, 2006 Author Share Posted December 1, 2006 Timing belt?Oh yeah... I'm an idiot...a big one... Wait, what if it's not? Any other ideas? (Not that I don't believe you...) Quote Link to comment Share on other sites More sharing options...
Manarius Posted December 1, 2006 Share Posted December 1, 2006 Crank or Cam position sensors. Assuming it's not a hot start issue. Quote Link to comment Share on other sites More sharing options...
backwoodsboy Posted December 1, 2006 Share Posted December 1, 2006 If its got air, fuel, and spark......it should run (unless the t-belt is all done, or JUMPED time) Everything else I can think of would just make it run poorly. :-\ Quote Link to comment Share on other sites More sharing options...
backwoodsboy Posted December 1, 2006 Share Posted December 1, 2006 Crank or Cam position sensors. Assuming it's not a hot start issue. .....or that :-\ Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted December 1, 2006 Share Posted December 1, 2006 .....or that :-\ so the wires are good, is the spark??? coil pack. ??? Quote Link to comment Share on other sites More sharing options...
nipper Posted December 1, 2006 Share Posted December 1, 2006 Lets start with basics, do you have spark, and if you do is it a strong spark.. nipper Quote Link to comment Share on other sites More sharing options...
tcspeer Posted December 2, 2006 Share Posted December 2, 2006 Open your gas cap and put your ear there while someone turns the key on, and listen to see if the fuel pump runs for just a few seconds. I just take the line off at the filter and turn the engine over but this can be dangerous, the other way is safer. Quote Link to comment Share on other sites More sharing options...
burtonsnowman Posted December 4, 2006 Author Share Posted December 4, 2006 Timing belts are good...I'll try the fuel pump thing... Quote Link to comment Share on other sites More sharing options...
