fuel leak above tank
10 replies to this topic
#1 Dangerdave
Dangerdave
    USMB Regular
  • PipPipPip
  • 62 posts
  • Waterloo
Posted 02 December 2006 - 04:48 PM
Hey,
I have a 93 awd legacy with a fuel leak. Fuel is running down one line from above the tank. It looks like It will have to be removed. Any advice for removal? I've searched and it looks like I'll have to remove the driveshaft, exhaust and the rear cross-member. Is that right? Any advice on how to proceed would be great.
Thanks very much
Dave
#2 tcspeer
tcspeer
    1000+ Super USER!
  • 1,444 posts
  • Walnut Springs
Posted 02 December 2006 - 04:56 PM
Did you check to make sure some of the hose connections at the fuel pump are not leaking?
Hey,
Thanks very much
Dave
#3 Manarius
Manarius
    1995 Subaru SVX LSi
  • 1,609 posts
  • Grantham
Posted 02 December 2006 - 04:57 PM
I'd be willing to bet he has the leak from the neck. That's a fairly common one.
#4 Dangerdave
Dangerdave
    USMB Regular
  • PipPipPip
  • 62 posts
  • Waterloo
Posted 02 December 2006 - 05:37 PM
Thanks for the replies. I should have mentioned that the leak is on the driver's side. Where exactly is the fuel pump? How do I access it? By neck I guess you mean the filler neck? It's pretty clean as far as I can tell.
Another thing I've heard mentioned is the sending unit access door? I pulled the rear seat out. I can see a rubber grommet with lines going through them on each side. Are those what I'm looking for?
Dave
#5 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 02 December 2006 - 06:20 PM
Dave
you don't want to pull the gas tank if you don't have to. on 95-99 the differential has to come out.
again on 95 -99 the sending unit access is between the trunk and the back seat under the carpet. with the seat out its eeasier to work from the car. with the seat in it's easier to work from the trunk.
the fuel lines run under the carpet on the driver side and through the wall/floor under the rear seat on the left (driver) side. there should be 2 or 3 of them. again, 95-99. my guess is that 90-94 is similar.
#6 nipper
nipper
    Semi Elite Master of the
  • 18,195 posts
  • Long Island NY
Posted 02 December 2006 - 06:21 PM
if its not on the filler neck side, it can be either a hose or sadly tank rot.
There are two access covers in the trunk where the fuel pump and sender are.
nipper
#7 Dangerdave
Dangerdave
    USMB Regular
  • PipPipPip
  • 62 posts
  • Waterloo
Posted 02 December 2006 - 06:27 PM
I pulled up the carpet in the trunk and didnt see anything. Am I looking in the wrong place?
#8 tcspeer
tcspeer
    1000+ Super USER!
  • 1,444 posts
  • Walnut Springs
Posted 02 December 2006 - 06:51 PM
I have the 97 wagon and mine is right behind the rear seat on the right side there is a metal plate covering it.
#9 Onearmwet
Onearmwet
    New User
  • Pip
  • 3 posts
  • new england
Posted 02 December 2006 - 11:18 PM
One of my 94 legacy postal rhd wagons had a fuel leak above the tank. i thought it was a big deal when i left it at the repair shop. the mechanic found a leaky fuel line and was able to splice in a new section of tubing, snaking it thru the fuel pump access plate in the floor behind rear seat.
#10 sidedown
sidedown
    New User
  • PipPip
  • 17 posts
Posted 02 December 2006 - 11:39 PM
Had the same problem on a '92 wagon I used to have. The access panel in the trunk or cargo area was covered by a sheet of tape sealant painted the same as the body of the car. Peel that back and the access plates will be visible. On mine, one of the lines on top of the tank was seeping and I was able to replace it through there to the connection by the left rear wheel. Also, had a problem where the filler neck was seeping at the bottom of its curve to the tank. That would be on the passenger side though. For that I just removed the bad section and patched in a new piece. Should be easy to see if that is the leak, the pipe looked pretty well soaked on mine.
#11 Dangerdave
Dangerdave
    USMB Regular
  • PipPipPip
  • 62 posts
  • Waterloo
Posted 03 December 2006 - 12:13 AM
I didn't peel that sealant back... thanks. I'm starting to feel alot better about this. The tank itself looks pretty good, but the lines are visibly rotten. Hopefully I can splice a piece of line in.
Thanks again,
Dave
