golfmasterii Posted December 10, 2006 Share Posted December 10, 2006 while driving my '91 Turbo today at approximately 55mph in Drive the overdrive suddenly quit working. The engine revved to about 4500rpm, the speedometer quit working the signals quit working and the cruise control quit working. The car will drive and shift normally through 3rd gear but will not shift at all in Drive. All other electrical problems continue whether in Drive or 1st-3rd? mark:-\ Quote Link to comment Share on other sites More sharing options...
Manarius Posted December 10, 2006 Share Posted December 10, 2006 Any check engine lights? Maybe a fuse blew. I would want to say the speedo is courtesy of a broken VSS, but I think that it all may stem from some fuse. Quote Link to comment Share on other sites More sharing options...
ericem Posted December 10, 2006 Share Posted December 10, 2006 you must have blown a whole lot of fuses, because i would think if the TCU werent gettings power you would need to shift manually, altough im not sure if it would work, but i guess it does. Quote Link to comment Share on other sites More sharing options...
nipper Posted December 10, 2006 Share Posted December 10, 2006 you are in limp mode. If you lost your spedo cable this will happen. one of the VSS sensors are in the spedo head, the other in the tranny. It is possible that you have one dead vss and a broken spedo cable nipper Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted December 10, 2006 Share Posted December 10, 2006 Replace this piece and you should be good. http://www.main.experiencetherave.com:8080/subaru/images/speedocablebase.jpg It's a common issue for the spinning shaft in the base piece to break. Quote Link to comment Share on other sites More sharing options...
Manarius Posted December 10, 2006 Share Posted December 10, 2006 Replace this piece and you should be good.http://www.main.experiencetherave.com:8080/subaru/images/speedocablebase.jpg It's a common issue for the spinning shaft in the base piece to break. One lousy piece causes all that problem. What a pain. Quote Link to comment Share on other sites More sharing options...
ericem Posted December 11, 2006 Share Posted December 11, 2006 One lousy piece causes all that problem. What a pain. definitly. Quote Link to comment Share on other sites More sharing options...
