mellow65 Posted December 24, 2006 Share Posted December 24, 2006 You know the old saying if you have to ask how much you probably can't afford it. Well it probably holds true to this also. How do you put a transfer case in a subaru? I mean i get where and how they work and the fact you put a front axle in and everything, but I have never really seen any pictures of how you mount a transfer case to the car. Do you make an add on frame that you mount it to? Or just support it from the floor? Pictures would be cool. I know someone had to keep a photo journal of their build. Quote Link to comment Share on other sites More sharing options...
Rollie715 Posted December 24, 2006 Share Posted December 24, 2006 I recently had the same question. I found if I went to the photo section and did a search for transfercase or differential, I found a few good pictures showing how others had done it. Then after you see who has some of the pictures, then go to their photo albums, and you may find more. If I remember right, Bushbasher had some really good ones that showed a lot of how he did it. Rollie Quote Link to comment Share on other sites More sharing options...
Numbchux Posted December 24, 2006 Share Posted December 24, 2006 virtually everyone builds a frame under the car. which I think is pretty much required to get enough strength for the suspension at the 6-8"+ of lift range. although bushbasher didn't. he reinforced the floor under the seats, and mounted it that way...it looked pretty cool. but I'm still worried about he front suspension. a frame really helps strengthen the weakest part of the car, the radius rod brackets. Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted December 25, 2006 Share Posted December 25, 2006 next month I will start my T-case conversion on my old red car and will detail it with pictures and stuff in a new thread , so far I have the car, have a Nissan t-case and have the 30" Kooks to install Quote Link to comment Share on other sites More sharing options...
GLCraig Posted December 26, 2006 Share Posted December 26, 2006 Here's a pic from WCSS#5. It's a pic of the underside Lumpycam's HatchBrat with a T-Case mod. http://www.ultimatesubaru.org/photos/showphoto.php?photo=13819&size=big&cat=500 Quote Link to comment Share on other sites More sharing options...
mellow65 Posted December 27, 2006 Author Share Posted December 27, 2006 ok well i understand now. basically the right way to do it is build a frame for the t-case and attach that to the front and rear so you dont tear it all apart. makes sense to me, but way more then i will ever do. thanks Quote Link to comment Share on other sites More sharing options...
dixracing Posted December 27, 2006 Share Posted December 27, 2006 i see now .....thanks :eek: Quote Link to comment Share on other sites More sharing options...
