91 Loyale Oil Leak, Help!
1 reply to this topic
#1 geobrown@aol.com
geobrown@aol.com
    New User
  • Pip
  • 1 posts
  • California
Posted 17 November 2003 - 01:42 AM
1.8L engine, 110 K miles, replaced rear main , front main, pan gaskets. Rear main failed 1000 miles, replaced again, failed again. Now leaking from front cover. Could something be causing crank case pressure to force oil through seals?
#2 TomRhere
TomRhere
    Certified BRAT nut!!!
  • 4,600 posts
  • Hillsdale, Mi. USA
Posted 17 November 2003 - 04:30 AM
Welcome to the board.
A clogged PCV system could be your troublemaker. Replace the PCV valve, and make sure all the hoses are clean. May even need to pull valve covers and clean those out to.
