Max Power Posted January 1, 2007 Share Posted January 1, 2007 When pulling ABS trouble codes from a 97 OB, code 46 comes up (as well as 22 & 42). I have been unable to locate any info for code 46. In addition, none of the codes can be cleared when following procedure outlined here. Anyone familiar with ABS trouble code 46? Thanks! mp Quote Link to comment Share on other sites More sharing options...
Max Power Posted January 1, 2007 Author Share Posted January 1, 2007 I was able to get rid of code 46 and it hasn't returned. I'm still curious as to it's significance, but it's not too critical. Thanks again, mp Quote Link to comment Share on other sites More sharing options...
OB99W Posted January 1, 2007 Share Posted January 1, 2007 When pulling ABS trouble codes from a 97 OB, code 46 comes up (as well as 22 & 42).[...] I don't have any info on code "46". However, since you got "42", I'd suggest checking the charging system before you do anything else, since low voltage can cause other codes to show. If that seems okay, look for possible loose/corroded connectors next. Quote Link to comment Share on other sites More sharing options...
