URGENT!! i need help tonight! 86 EA82
11 replies to this topic
#1 Subaru_Mechanic
Subaru_Mechanic
    Eat, Live, Breath Subaru
  • 295 posts
Posted 08 January 2007 - 11:29 PM
no spark??? what else do you need to know?
#2 grossgary
grossgary
    Elite Master of the Subaru
  • Gold Subscribers
  • 17,909 posts
  • West VA
Posted 08 January 2007 - 11:35 PM
no spark where? at the plugs or out of the ignition coil? first step is to determine that. if there's spark from the coil but not at the plugs then your problem is with the distributor cap, rotor, ignition wires or spark plugs. if there's no spark out of the coil then there are a number of possibilities that have increasing levels of difficult to figure out. first i'd swap in another coil and/or FET resistor (the little thingy attached to the coil bracket that bolts and grounds to the strut tower underneath the coil). this FET needs to be grounded well, make sure the bolt is in place and no funny business with the metal there..paint or rust issues?any other recent issues or work done? or the car was fine and then bam...no spark?
what engine/vehicle? carb, FI....etc?
#3 grossgary
grossgary
  • Gold Subscribers
  • 17,909 posts
  • West VA
Posted 08 January 2007 - 11:37 PM
i just edited my last post, check my more detailed revisions if you were constantly monitoring this thread.
#4 Subaru_Mechanic
Subaru_Mechanic
  • 295 posts
Posted 08 January 2007 - 11:46 PM
i just did an engine swap. and threres no spark outta the coil. there are three wires goin to it two yellow and one black. carb. 1986 coupe EA82 engine
#5 86BRATMAN
86BRATMAN
    Subaru Master
  • Gold Subscribers
  • 2,685 posts
  • Tazewell Virginia
Posted 08 January 2007 - 11:56 PM
have you checked for voltage going into the coil itself
#6 Subaru_Mechanic
Subaru_Mechanic
  • 295 posts
Posted 09 January 2007 - 12:03 AM
dont have a volt meter. but if there wasnt i need to fix it.
#7 grossgary
grossgary
  • Gold Subscribers
  • 17,909 posts
  • West VA
Posted 09 January 2007 - 12:07 AM
on the XT6 there's a ground wire going from the coil to the front drivers side of the engine. i don't know how an 86 EA82 is set up but i'd imagine there's a similar single wire ground wire going somewhere from the coil....is that connected?
this isn't that whacked out carb/ECU weird combo engine is it?
#8 Subaru_Mechanic
Subaru_Mechanic
  • 295 posts
Posted 09 January 2007 - 12:13 AM
ill check, yea it really is odd.:confused:
#9 Subaru_Mechanic
Subaru_Mechanic
  • 295 posts
Posted 09 January 2007 - 12:31 AM
ok nothing happened. the coil has a positive and a negitive. about how many wires go to it and what colors go where? where does the main battery ground go?
#10 Subaru_Mechanic
Subaru_Mechanic
  • 295 posts
Posted 09 January 2007 - 01:27 AM
okay i did a bunch of wire switching and nothing happened. i cant find any info on this either. i just swaped in a new engine and im not gettin any spark. the coil seems dead. what now:confused:
#11 NoahDL88
NoahDL88
    Elite Master of Cookies
  • 4,264 posts
  • Bremerton, WA, USA
Posted 09 January 2007 - 02:06 AM
Get yourself a volt meter, or at the very least a test light, you're not gonna be doing any electrical diag without it.
once you get the proper tools, check for 12 volts at the + side of the coil, and see if that's getting the juice.
After that pull the center wire off of the disty and hold it close to any metal part of the engine, and have a buddy crank over the engine, see if you have spark.
If you have spark there, its an issue with the disty connections, if you don't, your coil or wiring to the coil is bad.
#12 Singlecoil
Singlecoil
    USMB Regular
  • PipPipPip
  • 64 posts
  • Eatonville
Posted 09 January 2007 - 02:42 AM
The yellow wire goes to one of the side posts on the coil, and the black with white stripe goes to the other side post on the coil.
