Hose from throttle body to heater return pipe?
8 replies to this topic
#1 sid_vicious
sid_vicious
    USMB Regular
  • PipPipPip
  • 117 posts
  • Madison, WI
Posted 11 January 2007 - 10:18 PM
Hi,
I'm working on a Vanagon engine swap and I think I've discarded a small hose that I should have kept. The engine is a 1997 EJ25, 2.5L DOHC. The hose I'm looking for runs from the throttle body to the heater return pipe on top of the engine block. The hose makes two 90-degree bends, which makes me think I'm going to have a lot of trouble finding a replacement unless I have the Subaru part number and can just get an OEM hose. Anyone know where I can find it?
Thanks,
Andrew Harrison
#2 WoodsWagon
WoodsWagon
    Formerly 91Loyale
  • 4,102 posts
  • NH
Posted 11 January 2007 - 10:40 PM
Use regular 5/16ths coolant hose, it will make the two 90' without kinking. I chopped mine off geting the manifold off,and I replaced mine with fuel line (it was what I had on hand). and no problems yet.
Make that 3/16ths
my sizes are getting fuzzy, I changed mine last week, I know it was a 16th, I just forget which one. It's obvious if you look at the size of the nipple it goes on.
#3 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 12 January 2007 - 08:03 AM
Make that 3/16ths
3/16ths is tiny , think axel pin punch. .....................it has to be 5/16ths.
#4 sid_vicious
sid_vicious
    USMB Regular
  • PipPipPip
  • 117 posts
  • Madison, WI
Posted 12 January 2007 - 11:09 AM
I was thinking the hose was 3/8". Maybe 5/16, being 1/16 smaller than 3/8, is a little more flexible? I half-heartedly tried to fit a 3/8 heater hose in there, and it just didn't seem like it would work.
#5 Setright
Setright
    Elite Master of the Subaru
  • 3,176 posts
  • Denmark
Posted 13 January 2007 - 09:59 AM
Sid, are you sure you need it?
It's there to prevent throttle bodly icing. Is that a problem where you intend to use the vehicle? Is it indeed a problem where the engine is gonna live now?
#6 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 13 January 2007 - 10:50 AM
I have that exact OE hose for a 2.5L, after I run some erands I'll find it in the garage and take a picture of it in the package with part #. If you're in Wisconsin i'd guess it'll be cold enough there to want to keep the throttle body heat.
#7 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
  • Latrobe, Pennsylvania
Posted 13 January 2007 - 11:05 AM
Is this the hose you are talking about?
Posted Image
#8 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 13 January 2007 - 12:16 PM
Here's the pic; this is the throttle body to return pipe heater hose I ordered, although it does seem to look a little different from the engine pic Skip posted. The hose is fairly flexible and I can easily move it to the needed shape without kinking.
It appears to be 7.5mm hose based on the label, which would be right around 5/16"
Posted Image
#9 sid_vicious
sid_vicious
    USMB Regular
  • PipPipPip
  • 117 posts
  • Madison, WI
Posted 14 January 2007 - 01:24 PM
Posted Image
Sure enough. It's the hose on the right side of the photo by the white ground wire connector. The hose in porcupine's photo looks like it would be likely to do the trick. I read about this hose's function as a measure for ice prevention in the throttle body, and I'm sure I would be needing it in Wisconsin. How does one find such a part number? It seems there's always someone on the forum who has it, but it never comes up in the search engines on parts websites. It seems that if you know the P/N, they have it in stock, but you cannot find it just by searching the site? Is there a good source somewhere to find odd little parts like this? Anyway, thanks for the info, and I'll order up the hose.
