question about 79 wagon
15 replies to this topic
#1 shift
shift
    USMB is life!
  • 138 posts
  • houston
Posted 15 January 2007 - 12:21 AM
is it possible to take out the front cv axles with out the fluid leaking all over the place? im going to drift my car, but i dont want to mess up my tranny and was wondering if this is possible?
#2 SUBARU3
SUBARU3
    Moderator
  • Moderator
  • 2,830 posts
  • Dallas, Ft. Worth, Texas
Posted 15 January 2007 - 03:20 AM
Yes, you can remove the axles. The transmission stubs have seals independent of the CV axle, it's not like the rear center drive shaft. You don't need to remove fluid.
Todd
#3 shift
shift
    USMB is life!
  • 138 posts
  • houston
Posted 15 January 2007 - 02:59 PM
Todd
ok heres another question, if i rerplaced the cv axles(which i did) and i didnt get new seals, would that cause the tranny to leak fluid? because thats what is happening now. i was thinking ti was the tranny front seal but iono
#4 DerFahrer
DerFahrer
    Formerly subyluvr2212
  • 2,420 posts
  • Orlando, FL
Posted 15 January 2007 - 04:16 PM
It must have already been leaking fluid.
Where do you see it coming from?
#5 shift
shift
    USMB is life!
  • 138 posts
  • houston
Posted 15 January 2007 - 11:03 PM
the connection of the bell houstong or tranny (w/e its called) where it connects to the engine
#6 DerFahrer
DerFahrer
  • 2,420 posts
  • Orlando, FL
Posted 16 January 2007 - 03:59 PM
Could be leaking from the input shaft seal, or could be leaking from the rear main seal of the engine.
#7 SUBARU3
SUBARU3
    Moderator
  • Moderator
  • 2,830 posts
Posted 16 January 2007 - 04:11 PM
and neither of those are related to the CV axles.
Todd
#8 shift
shift
    USMB is life!
  • 138 posts
  • houston
Posted 16 January 2007 - 07:17 PM
Todd
true, but is there a possibility that it COULD leak from the cv axle seals?
#9 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,157 posts
  • Oregon City
Posted 16 January 2007 - 08:26 PM
it is possible but the rear mains on these like to have a hissy fit after many years and many miles on them. I've had a couple gen 1s that have had a weep from the input shaft but the rear main seal is usually the main source of a leak. Replace it because if you don't, it'll eat your clutch up and then you'll have to replace it anyways.
#10 SUBARU3
SUBARU3
    Moderator
  • Moderator
  • 2,830 posts
Posted 17 January 2007 - 01:54 AM
Yes, but he was referring to having all the fluid run out by just removing the axle. If the seals were leaking, they would leak with or without the CV/axle.
I 2nd that it is the rear seal.
Todd
#11 keltik
keltik
    Clearly an idiot
  • 578 posts
  • New Zealand
Posted 17 January 2007 - 03:42 AM
Does it still have the EA engine in it? Or is it snowing or something? :confused:
#12 shift
shift
    USMB is life!
  • 138 posts
  • houston
Posted 17 January 2007 - 03:30 PM
no its just a semi built original engine.
#13 shift
shift
    USMB is life!
  • 138 posts
  • houston
Posted 17 January 2007 - 03:33 PM
how can i remove my tranny w/o having to remove mt bolts from the exhaust mani.? im scared to try and remove them for the fear that i might break the bolts, and have to get them drilled out n replaced :(
or can i just pull out the engine and l leave the tranny on the car? what would be the more safer and easy way to go?
#14 DerFahrer
DerFahrer
  • 2,420 posts
  • Orlando, FL
Posted 17 January 2007 - 05:14 PM
The exhaust has to come off, whether you drop the tranny or yank the engine. It's especially necessary to remove the exhaust on these cars because they have no cats (the non-Cali ones anyway) and thus the manifold assemblies reach back farther than the new Subarus.
Use lots of PB Blaster and be very careful. Do it slowly. Worst case scenario, the studs will unscrew out of the head with the nut, and then you can just screw them back in and Loctite them.
#15 shift
shift
    USMB is life!
  • 138 posts
  • houston
Posted 17 January 2007 - 06:01 PM
hmmm.NEVER THOUGHT ABOUT IT THAT WAY! :grin: :banana: :clap:
#16 cricket
cricket
    Subaru Fanatic!
  • 372 posts
  • Houston, Texas
Posted 18 February 2007 - 07:59 PM
SHIFT: CLEAR YOU PM INBOX. Thanks, Ennio
