soobme Posted November 18, 2003 Share Posted November 18, 2003 If I remember right, U have a turbo x-over pipe on your EA81. If that's right, did U have any trouble with the standard oil pan being in the way? Quote Link to comment Share on other sites More sharing options...
MilesFox Posted November 18, 2003 Share Posted November 18, 2003 sorry to hijack, i have fitted na ea82 cross pipe on a regular ea81. i believe that the ea81 pipe is pretty much the same, but not as big around tow to add to the question, does it clear the front crossmember? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 18, 2003 Share Posted November 18, 2003 The EA81T x-pipe, and the EA82T x-pipe are the same (don't know about diameter tho). The head flanges on them are turned 180 degrees, sou you have to remove, or turn the spacers under the heads - which means the ASV(s) have to go. I think he said there's some tweaking involved, but I'm not sure exactly what... GD Quote Link to comment Share on other sites More sharing options...
Qman Posted November 19, 2003 Share Posted November 19, 2003 The EA81 turbo crossover is indeed the same as an EA82. It fits fine if you have the turbo crossmember. There is a cutout, or dent if you will, that allows for the up pipe portion of the crossover to go through. If you have a oil pressure gauge you will need to move it by adding a 90' fitting. The skid plate will need to be altered a little to accomodate the front side of the pipe. Not any issues with the pan or other clearance issues. The standard y-pipe will fit between both EA81 and EA82 engines. I sometimes forget which is which as they are very similar. Quote Link to comment Share on other sites More sharing options...
Adam N.D.J. Posted November 19, 2003 Share Posted November 19, 2003 I don't think that he is going to have to worry about the turbo x-member if he's doing whot I think he's doing. :-\ Quote Link to comment Share on other sites More sharing options...
