I have a 85 GL Wagon 4x4 with a carb. There is a vacuum line not attached to anything and I am not sure where it goes. It starts on the back of a vacuum diaphram that kicks up the idle by moving the throttle. Where does the other end of the line go???
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Mystery vacuum line???
Started by
Goatboy
, Nov 19 2003 01:12 AM
2 replies to this topic
#1
Posted 19 November 2003 - 01:12 AM
#2
Posted 19 November 2003 - 01:36 AM
It should go to a solenoid that is then plumbed into the intake somewhere. Look for a solenoid with only one line running to it from the intake, and an open port on it. This is prolly why you are dropping R's when you turn on the defroster (or A/c, i.e. your other post). The solenoid valves are usually green for this purpose, and have a two wire connector going to them, and two vacume lines (or suppose to have two vacume lines). There is a possiblity that someone may have removed the solenoid, so if you can't find one, look for a two wire connector that isn't connected to anything on or near the motor. Lotsa luck.
edit: Ohkay, I've been looking through some of my books, and I think I have the solenoid narrowed down, I think, I'm used to workin on EA81's, the EA82 may be different. But check your passenger side strut tower, between it and the firewall there should be the solenoids, two of them, along with some vacume hoses going to them, one of them will control the idle up for the A/c system. If no one has it by tomarrow I'll dig through my EA82 and see if I can find the exact one that does it (I have an 85 4wd with with A/c so it should be near the same place as yours, when I find it.)
#3
Posted 19 November 2003 - 09:17 AM
Sounds like that might be it. I plugged into the selenoid by the strut tower, there was nipple there that had no hose, and now it does the opposite. It races the engine when I turn on the defroster. But not everytime!!! Grrrr
