WAWalker Posted February 5, 2007 Share Posted February 5, 2007 First thing. I don't believe there is a "problem" with 2.2L head gaskets. Second. This is more of an informational, comparission (2.2L vs. 2.5L) thread. The cause of this failure is PAINFULLY obvious. I mean it hurts to look at these heads. Someone has replaced the head gaskets once already. Poor wrokmanship is the cause of failure here. OK, a little back ground on this one. 95K miles on car. Water pump, t-stat, radiator, and head gaskets have all been replaced. In what order is unknow. Combustion leaking into cooling system. Very small leak at time of diagnoises. Current owner said car has only over heated on him once, after a long trip at highway speeds. Engine block. To compair to the 2.5L. Basicaly the same. I am going to make some measurements later to determine differences. Heads. Beware this is going to get ugly. Looks like the last person to have these off laid them on the side walk, kicked them down the block and back, then put them back on:eek: Not so bad? Ok, the nasty scratches in the surface of the head is what caused the leak this time around. What lead to the first replacement I geuss I'll never know. Anyway. Some pics to look at. More info on the 2.2L engine to come. Maybe some head gasket pictures to compaire also. Quote Link to comment Share on other sites More sharing options...
Tech1967 Posted February 6, 2007 Share Posted February 6, 2007 Looks like they used a die grinder and a coarse cookie. Fast but NONO. Keep it coming, this is good stuff. Quote Link to comment Share on other sites More sharing options...
_Aramchek_ Posted February 6, 2007 Share Posted February 6, 2007 Hmm,I happen to have a mostly healthy looking 200k mile 2.2 sitting with a cylinder head off too,it's kind of interesting to compare to. What year is that engine? The pistons look different from the ones in mine. Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted February 6, 2007 Share Posted February 6, 2007 i could be wrong but looks to be a phase 2 Quote Link to comment Share on other sites More sharing options...
WAWalker Posted February 6, 2007 Author Share Posted February 6, 2007 Oh, I left that out. It is a '97. Quote Link to comment Share on other sites More sharing options...
