86 subie, ecu light
9 replies to this topic
#1 ivantruckman
ivantruckman
    4 inch lift
  • 956 posts
  • caro, MI.
Posted 08 February 2007 - 11:54 AM
hi all. im trying to find out how to read codes on an 86 gl, ecu light is on, the car was running slugish, i repaired the wire to the o2 sensor, it runs good now , but the ecu light is still on, thanks in advance, Ivan
#2 misledxcracker
misledxcracker
    Guy no one ever answers
  • 846 posts
  • Bullhead City
Posted 08 February 2007 - 12:40 PM
remove the panel under the dash, where the fuse box is...
the silver box with the red light is your ECU.
search around, its actually pretty easy to read the codes and "decipher" them
#3 mikeshoup
mikeshoup
  • 2,196 posts
  • Edgewater, CO
Posted 08 February 2007 - 12:45 PM
If the ECS light is on, the light on the ECU will be blinking. Remove the lower panel, there should be a light on the computer on the front of it.
http://www.ultimates...ead.php?t=49918
Lists the codes and what they mean.
#4 ivantruckman
ivantruckman
    4 inch lift
  • 956 posts
  • caro, MI.
Posted 08 February 2007 - 01:10 PM
Whoop Dare It Is, you guys rock, thanks
#5 ivantruckman
ivantruckman
    4 inch lift
  • 956 posts
  • caro, MI.
Posted 08 February 2007 - 01:15 PM
i didnt relize how the o2 sensor could affect a carburator, :banana:
#6 ivantruckman
ivantruckman
    4 inch lift
  • 956 posts
  • caro, MI.
Posted 08 February 2007 - 05:02 PM
what the heck is ignition pulse system, it keeps flashing "dash dot pause" i think this is elevin, the manual says ignition pulse system
#7 Loyale 2.7 Turbo
Loyale 2.7 Turbo
    The Mighty "BumbleBeast"
  • 7,528 posts
  • Roatán, Honduras.
Posted 08 February 2007 - 05:33 PM
http://www.ultimates....ad.php?t=49918 :)
Ignition Pulse System... I´m not Sure... it´s Somethin´ about the Crank Angle Sensor.
Look Here too: http://www.obd-codes.com/trouble_codes/subaru/1983-1988-subaru-carbureted.php
#8 misledxcracker
misledxcracker
  • 846 posts
  • Bullhead City
Posted 08 February 2007 - 05:49 PM
11 is fine, I believe.
But dont quote me on that...
#9 mikeshoup
mikeshoup
  • 2,196 posts
  • Edgewater, CO
Posted 08 February 2007 - 06:38 PM
If the ECS light is on while the engine is running, it is not okay.
#10 misledxcracker
misledxcracker
  • 846 posts
  • Bullhead City
Posted 08 February 2007 - 07:22 PM
I said "dont quote me on that" for a reason.
