Retrofit Heated Mirrors/Seats???
5 replies to this topic
#1 pearlm30
pearlm30
    Eat, Live, Breath Subaru
  • 354 posts
  • Tampa, FL/ Bethlehem, PA
Posted 21 February 2007 - 01:51 AM
I have a MY 95 outback with no heated mirrors/seats. Saw one 96 OBS limited with winter package. I am wondering if MY 95 is pre wired for such options? If not, can anyone provide some electrical diagrams?
Thanks
BTW, I did search and found some info on the heated seats swap, but no info regarding to the heated mirrors
#2 dmanaenk
dmanaenk
  • 312 posts
  • AA
Posted 21 February 2007 - 02:03 AM
For heated mirror you have to get the dash switch, swap the mirror assemblies (or install a heating element), run the wires under dash and splice a couple of connections. I plan to do it soon.
Do a search for "subaru factory service manual" and you'll find links to a site with wiring diagrams among other stuff.
#3 nipper
nipper
    Semi Elite Master of the
  • 18,188 posts
  • Long Island NY
Posted 21 February 2007 - 10:10 AM
http://www.scoobymod...orums/index.php?
GO there and search for heated seats. It tells you all you are asking.
nipper
#4 eagleb
eagleb
  • 255 posts
  • Milwaukie, OR
Posted 16 January 2008 - 07:19 PM
Has anyone done the swap yet?
I found a set of heated mirrors with switch for $100... if the job is easy enough I might grab them.
#5 nipper
nipper
  • 18,188 posts
  • Long Island NY
Posted 16 January 2008 - 07:33 PM
Mechanically they should bolt right in, and electrically that should be easy.
nipper
#6 Rooster2
Rooster2
    Subaru Master
  • 4,613 posts
  • Indianapolis
Posted 16 January 2008 - 10:03 PM
Last summer my wife broke off the pass door mirror on her 98 OBW Limited. It was impossible to find a Limited in a wrecking yard with the heated mirrors. So, I had to replace with a non heated mirror. It was simply a matter of not hooking up the two factory wires in the door wiring to the non heated mirror.
What was a bear was removing one of the philips headed screws that is accessed through a hole in the door frame. It takes a drive with the proper size philips head to get enough leverage to loosen. A regular screw driver will not give you enough leverage.
Good luck on the update. I hope you can find the replacement mirrors easily.
