ej fuel lines?
14 replies to this topic
#1 Uberoo
Uberoo
    Subaru Wheeler
  • 3,862 posts
  • lewiston,ID
Posted 01 March 2007 - 01:13 AM
the Ej22 has two fuel rails.so does that mean two fuel lines?If so how do I go from one output on the fuelpump to to lines?Have a Y in the line?
#2 suberdave
suberdave
    www.suberdave.com
  • 1,004 posts
  • Covington
Posted 01 March 2007 - 01:28 AM
one is a fuel in. and the other is the fuel out. that passes the fuel regulator. one from the tank the other back to the tank.
-=Suberdave=-
www.suberdave.com
#3 Uberoo
Uberoo
    Subaru Wheeler
  • 3,862 posts
  • lewiston,ID
Posted 01 March 2007 - 01:55 AM
fuel in is the only line that needs to be fi grade?
#4 Phizinza
Phizinza
    Yip yip
  • 3,939 posts
  • South Australia
Posted 01 March 2007 - 08:32 PM
I am upto this stage too.
My questions were going to be:
Will the stock tiny return line be ok with the amount of fuel flowing thru the lines? And for those who have done it, did you adapt the fuel rail return line (same as the supply) down to the smaller EA return line? Also is the return line in the EA81 the same as the EA82? I'm pretty sure the EFI EA82 has the proper size for EFI both ways.
I'm thinking of making an adapter on the lathe to fit the EJ's return line to the EA's return line, and then just running that and hoping that the fuel pump doesn't pump much air when running a low tank.
I figured the Y adaptor pipe at the back of the pump won't work..
Tank fuel - Engine return
...... Fuel Pump ............
Because if you get air in the line the fuel pump will just pump it around, and that's no good. So you need the return line completely seperate and just going into the tank. But Then I was worried the small return pipe into the tank might not take the fuel flow the pump is putting out and there for would build pressure and maybe burst! :eek:
I'm getting the feeling I am thinking to hard on this one, what has everyone else done? :confused: :clap:
#5 s'ko
s'ko
    RIP
  • 1,722 posts
  • Los Angeles
Posted 02 March 2007 - 12:04 AM
I am at the same point too.
On the EA81 from with I figured out, the large hard line on the drivers side is the fuel in. the smaller one on that side is the fuel return line. The one in the middle of the firewall is the vapor line. So if you plug the return line and then get a new hard line and make my own thicker return line that should solve the pressure problem.
Unless of course no else is having problems with their stock system.
BW
#6 Phizinza
Phizinza
    Yip yip
  • 3,939 posts
  • South Australia
Posted 02 March 2007 - 04:13 AM
I think you'll find your self mistaken there. The little one in the middle is return, the biggest one is supply and the size inbetween is vent..
#7 Uberoo
Uberoo
    Subaru Wheeler
  • 3,862 posts
  • lewiston,ID
Posted 03 March 2007 - 01:53 AM
what about for the EJ there is like 2-3 lines that are the same diameter...
#8 Phizinza
Phizinza
    Yip yip
  • 3,939 posts
  • South Australia
Posted 03 March 2007 - 02:30 AM
Look closely at the fuel rails and the three pipes coming off the left side of the EJ. You'll see one goes into a line that leads right over to the charcol canister, one leads to the right head fuel rail and one to the left. The fuel in goes into the top one of those three pipes on the left side of the motor. Into the right head I think.
#9 Uberoo
Uberoo
    Subaru Wheeler
  • 3,862 posts
  • lewiston,ID
Posted 11 March 2007 - 04:47 PM
Roughly how much FI grade hose do I need of the various diameters for ej swap?I looked the the hoses and most of it is metal.
IE how much X" hose do I need,How much Y hose do I need to change the return and supply lines.
#10 baccaruda
baccaruda
    YOUR FAVORITE MOD
  • Moderator
  • 6,950 posts
  • SpoVegas, WA
Posted 11 March 2007 - 07:34 PM
just get like 5 feet so you have extra.
#11 Uberoo
Uberoo
    Subaru Wheeler
  • 3,862 posts
  • lewiston,ID
Posted 11 March 2007 - 08:20 PM
which right?Right from when you stand in front of the engine with engine in car or right with you in the driver's seat?
#12 Phizinza
Phizinza
    Yip yip
  • 3,939 posts
  • South Australia
Posted 12 March 2007 - 01:02 AM
The right is the right side of the car. When talking about engines and cars with lefts and rights we normally always mean the objects right or left. Not your perspective on the object.
I bought 3meters of 8mm EFI hose. I used a new soft line return (ripped out the old return) and a few different adaptors. It's all covered in my thread.
I have about 600mm left of it.
Ofcause, on the return it does technically have pressure so normal hose may work... But for safty reasons I used EFI until it got to the tank, then I used the 6.3mm and 3.2mm normal hose for the return into the tank. Tank to pump should always be EFI rated, just in case it can't cope with the vacuum in it.
#13 Uberoo
Uberoo
    Subaru Wheeler
  • 3,862 posts
  • lewiston,ID
Posted 19 March 2007 - 11:55 AM
um does the fuel supply go to the regulator?Or did I get the hoses mixed up?
#14 Numbchux
Numbchux
    EJ conversion addict
  • 6,871 posts
  • Saginaw, MN
Posted 19 March 2007 - 03:33 PM
the regulator should be on the return side, the high pressure side (from the pump/filter) goes opposite that.
#15 azbret
azbret
    USMB Regular
  • PipPipPip
  • 65 posts
  • Chandler, AZ
Posted 07 July 2007 - 09:56 PM
It seems to that no matter what size line you run back to the tank is a moog point because once you're there the fuel still has to return thru a small pipe back into the tank. Just a thought... Bret
