Turbo help
12 replies to this topic
#1 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 22 November 2003 - 11:56 AM
While I was up wheelin' yesterday oil started to shoot out all over my down pipe, and I was blowing blue smoke out the exaust REAL bad. We checked the feed & retern lines to the turbo but couldn't find any problems with them. It looked like it was coming from the center section of the turbo it's self on the under side some where. I tryed to crimp the feed line to the turbo but I don't think it worked caus it's still spining fine, with no noise and making good boost. After I got it back into town and drove it around for a while it stoped smoking, and it's not shooting oil any where:eh: It's still making boost, and the turbo is not making any bad sounds. I dont get it! What hapend??? Should I replace/fix the feed line and see what hapens or what. I don't want to drive it any more with the line criped off if the turbo is not shot.
#2 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 22 November 2003 - 12:01 PM
you must have not crimped the line all the way, because if it was runing dry, it wouldnt spin.
#3 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 22 November 2003 - 12:04 PM
That's what I thought! But now that it seems to have fixed it's self:temper: I don't want to starve it for oil. But I don't want it to start spuewing agen either:cornfuzz:
#4 toybuilder
toybuilder
    Subaru Fanatic!
  • 458 posts
  • Longmont
Posted 22 November 2003 - 12:07 PM
You need a new turbo. My RX is doing a similar thing. It still makes good boost, but is a little noisy when it spools up. Once the boost comes on I lay down a "spy hunter" style smoke screen. If I stay off the gas and the boost never comes on, no smoke. I believe that the oil seals are shot.
Good luck
#5 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 22 November 2003 - 12:11 PM
Right now I can get on the boost all the way up to 11psi and no smoke, no sounds , nothing. But whaen I was coming off the hill yester day, all the way to my house it was smoking like a b@$terd:eek: Then When I fierd it up 15-20min. later and drove it around town it was fine. And it's not shooting oil every where any more:eh:
#6 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 22 November 2003 - 04:06 PM
I just talked to a local Suby guy and he said somthing about an -O- ring that gos out on the turbo some where that will cause this type of problem. Any one know what he is talking about?
#7 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 22 November 2003 - 10:55 PM
could the oil return hose have puked?
#8 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 23 November 2003 - 02:55 AM
I'm thinking that is a poss. It looks OK, but looks are deceving:temper:
Ever seen one re seal it's self? Even if only temporaraly?
#9 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 23 November 2003 - 02:58 AM
its a silicone hose, so replace it with silicone.
its a good idea to replace the water hose off the turbo, as they can blow out.
i put jim's turbo motor together, got the whole car with blown headgaskets, never seenit run.
diring the build i suggested replacing the hose, but we didnt have the right size.
and then it blew out on the maiden voyage.
replace those hoses in one shot as preventative maintenance!
#10 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 23 November 2003 - 03:41 PM
Well...I gess that I wil un-crimp the oil feed line and see what hapens. If it just starts to shoot oil agen I can allwayse cut and fold the line to stop ALL oil flow to the turbo and wait for it to sease up. Will it still run with the turbo seized? I know it would be down on power big time, but will it run?
#11 Nug
Nug
    Lurker/off-topic poster
  • 1,968 posts
  • West Point, VA
Posted 23 November 2003 - 03:49 PM
It will run like rump roast. You have to think about the metal particles from the blown up turbo bearings that will find their way into your oil.
#12 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 23 November 2003 - 08:02 PM
Thank U!!!! I hadn't thought of that:eek: I will need to plug the return line too:o I figure I can wire the waste gate open to help with exaust flow.
I should come up with an intake hose for it to by-pass the turbo.
#13 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 25 November 2003 - 05:03 AM
Well, I un-criped the line as best I could. So far no oil leak:cornfuzz: and the turbo is doing great:cornfuzz: :cornfuzz: I can't for the life of me figure out what happend:drunk: I'm not crazy, I have 4 witneses who saw how much oil was coming out.
