Ea82T heads to Gen3 heads
21 replies to this topic
#1 desert dweller
desert dweller
    USMB Regular
  • PipPipPip
  • 48 posts
  • Big Water, UT
Posted 11 March 2007 - 10:51 PM
What's involved in swapping ea82t heads for gen3 heads?
#2 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,157 posts
  • Oregon City
Posted 11 March 2007 - 10:57 PM
I'm not following what you're asking. Are you asking what is involved with swapping the stock EA82T heads (probably gen 1) on your wagon for gen 3 heads? If so, you need to remove the intake, exhaust, valve covers, cam cases, lifters, rockers, unbolt the heads, load the new heads up with your valves, springs, new seals, install lifters, install rockers, install cam cases, valvecovers, intake and exhaust. All of which is going to have to be done outside the car for easiest workability. Turbo will also have to come off as well.
#3 desert dweller
desert dweller
    USMB Regular
  • PipPipPip
  • 48 posts
  • Big Water, UT
Posted 11 March 2007 - 11:02 PM
What gen 3 heads fit?
#4 mikeshoup
mikeshoup
  • 2,196 posts
  • Edgewater, CO
Posted 11 March 2007 - 11:04 PM
All Gen 3 heads fit... Gen 3 heads btw, were not put into any production vehicle to my knowledge. Maybe in really late 89s or the 90 Loyales. Can be purchased from Subaru though.
I was head shopping at junkyards trying to find these mythical gen 3 heads. an 89 GL-10 FT4WD Turbo Wagon still had the Gen 2 heads.
Why you swapping the heads anyways? IMO, no reason to do so unless you have cracked heads.
#5 jeffast
jeffast
    f*** im 24
  • 2,029 posts
  • midwestren
Posted 11 March 2007 - 11:12 PM
gen 3 heads were only installed in at dealer ships no car came with them from the factory thus why they're uber rare
#6 desert dweller
desert dweller
    USMB Regular
  • PipPipPip
  • 48 posts
  • Big Water, UT
Posted 11 March 2007 - 11:20 PM
For some reason a push rod came through the valve cover. I bought the car this way. I'm just trying to figure out if it's worth it to try and make this motor work or wait to find a ej22.
#7 mikeshoup
mikeshoup
  • 2,196 posts
  • Edgewater, CO
Posted 11 March 2007 - 11:23 PM
Pushrod? Your car has no pushrods.
#8 desert dweller
desert dweller
    USMB Regular
  • PipPipPip
  • 48 posts
  • Big Water, UT
Posted 11 March 2007 - 11:30 PM
I meant lifter. I haven't really looked at it closely yet.
#9 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,203 posts
  • WA
Posted 11 March 2007 - 11:52 PM
Make sure the heads came from a turbo. I believe the cams are different.
Eh, after some reading, I see they were only for turbo and SPFI.
#10 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,704 posts
  • Portland
Posted 12 March 2007 - 12:03 AM
If a rocker shot through the valve cover then there's a high likelyhood that the piston is shattered from hitting the valve. In which case - engine is toast :dead:
And as far as Gen 3 heads, there's nothing different about their fitment, but they are almost impossible to find as they were only availible from the dealer after EA82T production had ceased.
#11 desert dweller
desert dweller
    USMB Regular
  • PipPipPip
  • 48 posts
  • Big Water, UT
Posted 12 March 2007 - 12:10 AM
Cool thanks for the help guys. I'll probally pull the heads out of curiosity, but the info will help.
#12 tizzle
tizzle
    Subaru Nut
  • 628 posts
  • Bellingham
Posted 12 March 2007 - 01:12 PM
There not that impossible to find, you can still order them new, I have. I think there is only 70 or brand new ones left out there though
#13 carfreak85
carfreak85
    Temple of Fuji
  • 5,247 posts
  • Cascadia
Posted 12 March 2007 - 02:28 PM
How much did that set you back, if you don't mind my asking?
#14 tizzle
tizzle
    Subaru Nut
  • 628 posts
  • Bellingham
Posted 12 March 2007 - 02:43 PM
$317 for a new head, but I had subaru bucks to pay for it all. I got them from subiegal at https://www.subarugenuineparts.com
#15 88RxTuner
88RxTuner
    USMB is life!
  • 160 posts
  • Back in my DESERT!! SoCal
Posted 12 March 2007 - 03:02 PM
When I built the engine for my RX this winter, the heads list@ 350+- each, and I got one each left and right out of 24L 17R left in the US.. at least, that's what my dealer told me.. *glad I kept that piece of paper...*
#16 daeron
daeron
    Cunning Linguist
  • 3,600 posts
  • West Palm Beach
Posted 13 March 2007 - 12:57 AM
whats different about the gen 3 heads?
since I am being a lazy troll and not searching, may as well troll another question and ask, for that matter, whats the difference between the gen1s and the gen 2s, and what year did they change? a link would suffice, but I have been keeping my eyes peeled for almost a year now trying to figure this out, to no avail..
#17 TarmacSuby
TarmacSuby
    New User
  • PipPip
  • 25 posts
  • Lakeland
Posted 13 March 2007 - 01:07 AM
Why would the piston be damaged from the valve if the EA82 is a non-interference engine? Just wondering... Or have I been mistaken thinking that this whole time?
#18 daeron
daeron
    Cunning Linguist
  • 3,600 posts
  • West Palm Beach
Posted 13 March 2007 - 01:32 AM
No, you are right.. BUT..
..the rocker's explosive appearance outside the cylinder head would indicate something mighty afoul with the valvetrain, even with a non interference engine. What cause the rocker to shoot off in that direction? probably inertia from the piston travel. how did that inertia get transferred to the rocker arm? probably a stuck valve. Hence, KABLOOEY!!! :dead:
In other words, yes, they ARE non-interference engines, but that just means that the valves won't get hit if the timing belt breaks. It doesn't mean the valves are immune to the pistons, and it CERTAINLY doesn't imply that there is like, three inches of room between the piston and the valve at all times :-p
#19 GeneralDisorder
GeneralDisorder
  • 21,704 posts
  • Portland
Posted 13 March 2007 - 11:00 AM
Valve gets stuck; rocker arm falls off; rocker is pinched between cam and valve stem; stem breaks off; valve spring and retainer come apart; valve is sucked into cylinder; piston slams valve against head repeatedly resulting in a valve shaped like this: "V" and a shattered piston and destroyed cylinder..... That's usually how it happens.
#20 Loyale 2.7 Turbo
Loyale 2.7 Turbo
    The Mighty "BumbleBeast"
  • 7,528 posts
  • Roatán, Honduras.
Posted 13 March 2007 - 11:08 AM
Oh my God... Massive Destruction! :eek:
Why it Happens? :confused:
#21 88RxTuner
88RxTuner
    USMB is life!
  • 160 posts
Posted 14 March 2007 - 02:39 PM
Daeron...
Basically, and someone correct me if I'm wrong, the Gen3 heads have wider valve spacing in the head, which helps reduce the cracks that appear between the seats. They also have thicker casting in the exhaust port area, where these heads are notorious for cracking and leaking coolant. Generally speaking, they are an overall better casting of the same head.
#22 88RxTuner
88RxTuner
    USMB is life!
  • 160 posts
Posted 14 March 2007 - 02:42 PM
As far as that whole 'through the rocker cover' exit strategy the lifter took... I cant say I've ever seen or heard of such a thing, but if that's in fact what happened I would have to agree that something had to create that force on the rocker/lifter.. maybe piston?
Keep us posted, love to hear how it tears down...
