backwoodsboy Posted March 30, 2007 Share Posted March 30, 2007 Ok..... Last summer I hit something with my brat, and broke an "ear" on the EGR manifold where it bolts to the head. The two bolts that hold it to the head are strange, and seem to be larger than 13mm......but a 14mm is sloppy. There are also "TORX" slots in the center of each bolt. I cant get a socket (even if I had a 13 & 1/2mm) straight on the bolt heads, because the lower flange of the EGR manifold sticks out too far! Im thinking that this must call for a "special" subaru tool? My crappy but enlightening ms paint diagram can be seen here: http://www.ultimatesubaru.org/photos/data/954/MANIFOLD.JPG Thanks for any help! Quote Link to comment Share on other sites More sharing options...
hatchsub Posted March 30, 2007 Share Posted March 30, 2007 That pipe is actually your ASV valve pipe..not EGR. It was meant to introduce clean air from the air cleaner to the exhaust. As for the bolts you are refering they are indeed a Torx bolts. Last time i took a look under there it looked like a royal pita to get those things off. If i understand correctly you damaged that spacer and now need to take it off? I would get some PB blaster and soak the crap out of those two bolts..maybe even start the car up and get those bolts really hot before you try and get them off. As for a special tool i dont think there is one. I think you just have to be somewhat creative..as using a torx wrench will not do it at this point i doubt. maybe cut the sides of the bolt down with a file so that a socket fits snuggly on it. Thats something that i would probably do. BAP ( big a$$ pair) of vise grips might also help. Sorry if this doesnt help you too much. I hate exhaust work and feel your pain. good luck Quote Link to comment Share on other sites More sharing options...
backwoodsboy Posted March 30, 2007 Author Share Posted March 30, 2007 Thanks for the reply. I was REALLY hoping that there was some "secret" to this.....but there never really is I guess. :-\ I guess that creativity is just gonna have to be the key to this baby. BFvicegrips and the mapp gas torch might just do it. Quote Link to comment Share on other sites More sharing options...
darlingchip Posted March 30, 2007 Share Posted March 30, 2007 Sounds like its going to be a fun weekend already:banana: Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted March 31, 2007 Share Posted March 31, 2007 ...Last summer I hit something with my brat, and broke an "ear" on the EGR manifold where it bolts to the head. ... i´ll Try to Figure out that... Well... Good Luck! Quote Link to comment Share on other sites More sharing options...
Gloyale Posted May 6, 2007 Share Posted May 6, 2007 nevermind, I read it wrong. I need to go to sleep Quote Link to comment Share on other sites More sharing options...
