Guest Brettm57 Posted July 27, 2003 Share Posted July 27, 2003 My Legacy idles kind of rough most of the time when it's in gear (auto tranny) and on ocasion stalls when idling in gear, like when setting at a red light. Can anyone give me any idea where to start looking for the problem? Thanks. Quote Link to comment Share on other sites More sharing options...
Guest Legacy777 Posted July 27, 2003 Share Posted July 27, 2003 have you done all the routine maintenance like plugs, wires, filters, etc. You may want to go to an autozone to have them pull the codes to see if anything is in there. Quote Link to comment Share on other sites More sharing options...
Guest alia176 Posted July 27, 2003 Share Posted July 27, 2003 Add to Josh's comment the vacuum hoses. You may have a cracked/split end. For high mileage car, simply replacing them all is a good/cheap practice. Ali Quote Link to comment Share on other sites More sharing options...
Guest drOutback Posted July 27, 2003 Share Posted July 27, 2003 a MAF sensor could also be causing this problem while not throwing a code. Quote Link to comment Share on other sites More sharing options...
