Only highmount brake light illuminates when brake pedal is pressed 1994 Legacy Wagon
7 replies to this topic
#1 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 13 April 2007 - 03:47 PM
On this 1994 Legacy L Wagon, when pressing the brake, only the highmount/third brake light illuminates. The left and right stop lights do nothing. The left and right taillights illuminate if the parking/head lights are on, but there is no change when pressing the brake.
Just wondering if this is a common issue or what wiring areas to check. Maybe this issue was already addressed in another post... Thanks! :)
Posted Image
#2 Hendrik
Hendrik
    USMB Regular
  • PipPipPip
  • 123 posts
  • Holland and Brazil
Posted 13 April 2007 - 04:08 PM
Posted Image
Sometimes there is a `Stoplight Checker` , build in the right tail lamp.
Has 3 reed relais and the current flow for both brake lights goes over this circuit. Just check it.
#3 jamal
jamal
    1000+ Super USER!
  • 1,015 posts
  • Los Angeles
Posted 13 April 2007 - 05:01 PM
I think the bulb has separate elements for the brake and tail lights. Is it possible they're just both broken?
#4 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 13 April 2007 - 05:47 PM
Hendrick, thanks I will look for this stoplight checker. Jamal, good point, I thought about that today, it is entirely possible that both stop lamp elements are simply blown out. I will check it out. :burnout:
Since I just got this vehicle I've got my 10 day temporary NYS inspection sticker and the list of things checked in a NYS safety inspection and am trying to make sure everything is in order before going in.
#5 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 13 April 2007 - 07:26 PM
Schweeeet! Problem solved. One bulb was blown out, the other just had a bad connection in the socket. Replaced both bulbs and it's working! Thanks you guys! :banana:
Here's the story in pictures: Yes there is some weird relay contraption on the RH side:
Posted ImagePosted Image
Then I put in these new bulbs:
Posted Image
With some of this grease on the contacts and stuff:
Posted Image
And this is what happened: (:banana:)
Posted Image
#6 ericem
ericem
    First Gen Legacy Master
  • 2,477 posts
  • CANADA Maple,ON
Posted 13 April 2007 - 09:48 PM
yay! :banana:
#7 nipper
nipper
    Semi Elite Master of the
  • 18,195 posts
  • Long Island NY
Posted 14 April 2007 - 12:51 AM
Bulb Grease? Thats a first.
Maybe i really do need to check to see if they have synthetic blinker fluid.
nipper
#8 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 14 April 2007 - 06:33 AM
Hm...maybe I should see if they have synthetic bulb grease! :cool: and might as well put in the low-friction muffler bearings while I have it up.
Not sure what in this bulb grease. It's a white paste. I suspect it's silicone grease with some sort of cleaner in it. If put on a tarnished connection it will make it shiny after a while.
Haven't had any stuck in the socket bulbs on the Suby's though even without this grease. Started using it on the 'ol 88 lincoln 'cause the bulbs liked to rot into the sockets making them impossible to get out. This stuff seemed to help.
