wrxsubaru Posted November 26, 2003 Share Posted November 26, 2003 While i was taking out the auto out of my SVX iI restd my hand on the ac hose going from the ac compresor to the fire wall, and when I lifted my hand off of it it started to hiss/leak it leaked for about 20-30 mins at the end of the hose were it conects to the compresor. Is thee a gasket, I tried tightening it down but it dident stop or even slow down the leak because the bolt was already tight. ANy ideas on how to fix it? THANKS Quote Link to comment Share on other sites More sharing options...
nathan Posted November 26, 2003 Share Posted November 26, 2003 the ac hoses have o rings. It doesn't make sense that the oring could have been disturbed with hand pressure unless it was very loose and then it would have been leaking from the ac pressure. My guess is that you cracked the hose or metal fitting when you leaned on it. Get a new hose from junkyard and refill the system with on of those r134a systems you can get from the auto store, it's cheap and it works. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted November 26, 2003 Share Posted November 26, 2003 yeah check o-rings and retrofitting does work. I am pretty sure I posted instructions on retrofitting my legacy....doing a search should show something. Quote Link to comment Share on other sites More sharing options...
p.monro Posted November 27, 2003 Share Posted November 27, 2003 Here is the link to Josh's original article http://pub110.ezboard.com/fultimatesubarumessageboardsfrm6.showMessage?topicID=110.topic Quote Link to comment Share on other sites More sharing options...
