MaroonDuneDoom Posted November 26, 2003 Share Posted November 26, 2003 can't remeber how to easily tell the difference. anybody? Quote Link to comment Share on other sites More sharing options...
Scrub2k Posted November 26, 2003 Share Posted November 26, 2003 Look for injectors, SPFI will have one injector MPFI will have 4 or more i think, their might be an easier way to tell, but at least a free bump BUMP! Quote Link to comment Share on other sites More sharing options...
MaroonDuneDoom Posted November 26, 2003 Author Share Posted November 26, 2003 ridiculously stupid question: what do the injectors look like? what are they next to? Quote Link to comment Share on other sites More sharing options...
Scrub2k Posted November 26, 2003 Share Posted November 26, 2003 ok Maybe thats not an easy way to tell, i just went out to the garage and looked at mine and i can't even see the injectors on mine, so hopefully someone else will pipe in and help you out, sorry Quote Link to comment Share on other sites More sharing options...
MaroonDuneDoom Posted November 26, 2003 Author Share Posted November 26, 2003 i'll look through my .pdf manual. thanks anyways man. Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted November 26, 2003 Share Posted November 26, 2003 if the top is black and says Subaru FI then its spfi, one injector, under the rubber hose. the MPFI had injectors near the spark plugs, if you don't see anything around the spark plugs then you have spfi, in a GL non turbo or non GL-10 then you have spfi. Quote Link to comment Share on other sites More sharing options...
electryc_monk Posted November 26, 2003 Share Posted November 26, 2003 heres a hint from a MPFI user. SPFI intakes will have a hose that goes into the EA82 intake parallel to the crankshaft and will be a long hose similar to the hose of an XT6 intake. (after the MAF to the aluminum manifold) the MPFI (exception is the coveted spider intake) will be a perpendicular vertical intake tube that has a molded plate with MPFI or Subaru FI molded into the plastic intake tube's top surface. Case in point to keep one thinking this way, its how you can tell its a turbo model as the turbo uses a aluminum perpendicular intake setup which is (basically speaking) the same as the MPFI intake. (that's why you can see the molded "Turbo" or "4wd Turbo" or "subaru Turbo" on its top serface. That work better for you? simple question, yes. stupid? no. Quote Link to comment Share on other sites More sharing options...
