SoobItUp Posted May 1, 2007 Share Posted May 1, 2007 how do i remove the side body trim from my wagon? i'm gonna put full body graphics on the sides and i need to remove the trim. any suggestions? thanks!!! Quote Link to comment Share on other sites More sharing options...
Gloyale Posted May 1, 2007 Share Posted May 1, 2007 You have to get behind the panel. By pulling door panels, trunk panels, inner fender and such. The clips must be squeezed and then pushed out of their holes. If you just pry you will garaunteed break the clips. Heck, even if your careful you may break some, so you may want to practice by going to a wrecking yard, and pulling trim on one there. Grab a bunch of the clips as extras. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted May 1, 2007 Share Posted May 1, 2007 if you are not worried about keeping the trims you can use a flat screwdriver and ahammer to pust them off at the clips from behind the rubber. Quote Link to comment Share on other sites More sharing options...
