figone Posted May 7, 2007 Share Posted May 7, 2007 OK... I'm getting a *pop pop pop* out of the drivetrain, sounds to be comming from the passenger's side (but that's when I'm sitting in the driver's side) that is wheel-speed (not engine speed) related. It pops when I'm going foward (but not reverse) and driving straight or turning right. No pops turning left, none when the load is taken off (such as when changing gears). The mounts look to be ok. It makes more noise when cold, then gets softer when warmed up. Once up to speed (4th or 5th gear) it seems to stop altogether, but that could just be that it's popping so fast I can't hear it anymore. Any thoughts? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted May 7, 2007 Share Posted May 7, 2007 OK... I'm getting a *pop pop pop* out of the drivetrain, sounds to be comming from the passenger's side (but that's when I'm sitting in the driver's side) that is wheel-speed (not engine speed) related. It pops when I'm going foward (but not reverse) and driving straight or turning right. No pops turning left, none when the load is taken off (such as when changing gears). The mounts look to be ok. It makes more noise when cold, then gets softer when warmed up. Once up to speed (4th or 5th gear) it seems to stop altogether, but that could just be that it's popping so fast I can't hear it anymore. Any thoughts? Thanks in advance. CV axle. Poping during turns, relative to vehichle speed, is a dead giveaway. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted May 7, 2007 Share Posted May 7, 2007 CV axle. Poping during turns, relative to vehichle speed, is a dead giveaway. most definitely. right side. when you turn right, the car leans away from that side, putting more angle/stress on that axle. when you turn left, it relieves the angles and stress.... Quote Link to comment Share on other sites More sharing options...
figone Posted May 8, 2007 Author Share Posted May 8, 2007 Thought it was that, so I replaced both cv's with new, not re-man ones. No change at all, even immediately after the swap. Thanks,though. Other ideas? Quote Link to comment Share on other sites More sharing options...
Gloyale Posted May 8, 2007 Share Posted May 8, 2007 I remember one time I got a cheap pair of front brake pads for my GL. They were missing the wear indicator/tensioner thing that is ussually riveted to the back of the pad.(the little flat strip or tab of metal looped over that starts to rub the rotor when the pad gets low). Well on Soobs it also holds the pads firmly in the brackets. Well these pads without it would catch on the rotor as it went round and knock back and forth in the brackets and make a sound I thought was my CVs for a long time. Take the wheels off and see if your pads have the tabs. If not, see if you can shift the pads in there brackets and make a knocking noise. Could this be what your noise is? I ended up fashioning some thin strips of metal, bending them over, drilling a hole, and fitting them onto the pins on the back of the pad. Had to use a punch to flare the the pin out to hold the tab. I could have just bought new, better pads, but I was young and broke then. I hadn't thought about that in years but it just occured to me that maybe?.... Quote Link to comment Share on other sites More sharing options...
figone Posted May 8, 2007 Author Share Posted May 8, 2007 Wouldn't that cause it to happen even with the clutch depressed? I'll check it out, though. Thanks Quote Link to comment Share on other sites More sharing options...
Numbchux Posted May 8, 2007 Share Posted May 8, 2007 yep, funky brake pads could also cause funky noises... also wheel bearings, or even something as simple as not getting the axle nut torqued down enough just judging by your description though, I don't think it's something in your tranny. Quote Link to comment Share on other sites More sharing options...
