Swapping a AT to an MT in a 97 Leg???
8 replies to this topic
#1 Hocrest
Hocrest
    Function becomes Fun
  • 1,344 posts
  • Cressona/Pittston
Posted 11 May 2007 - 06:12 PM
Has anyone swapped a manual into an auto Leg? It's time for it to happen to my '97. Anything odd I need to worry about?
#2 svxpert
svxpert
    Certified Subaru Nut
  • 777 posts
  • East Coast
Posted 12 May 2007 - 12:26 AM
its pretty straight forward. do you have the donor manual car? that helps alot. i have done that same swap to the following vehicles:
1. 1992 svx
2. 1991 legacy turbo
3. 1995 subaru impreza
4. 1997 legacy gt
make sure you don't cut any of the trans wires in the engine compartment- use donor ones that can still plug in and cut off about 4 inch from where they plug in. let me know if you run into any problems.
#3 Hocrest
Hocrest
  • 1,344 posts
  • Cressona/Pittston
Posted 13 May 2007 - 11:55 AM
One of my questions for the Legacy swap, is the wiring for the clutch switches and manual transmission in place but not used?
I've done the swap on an SVX, where none of the wiring is in place, just thinking maybe it already there on the Legacy since they did come with a 5 speed???
What about the cruise control computer??
#4 svxpert
svxpert
  • 777 posts
  • East Coast
Posted 13 May 2007 - 08:39 PM
<<One of my questions for the Legacy swap, is the wiring for the clutch switches and manual transmission in place but not used?>>
the clutch switch connector is there.
you will have to find the correct pins on the a/t connectors that were unplugged under the hood and connect them to the manual tranny.
<<What about the cruise control computer??>>
not sure about that.
#5 Crawlerdan
Crawlerdan
    Eat, Live, Breath Subaru
  • 328 posts
  • montana
Posted 13 May 2007 - 09:04 PM
we just finished up a 97 gt wagon with a JDM 4:11 5spd an lsd rear diff
#6 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,284 posts
  • Houston, Tx
Posted 14 May 2007 - 11:37 AM
Take a look at my writeup. It should be similar, with the exception about maybe having to get a MT ECU.
www.surrealmirage.com/subaru/swap
#7 grossgary
grossgary
    Elite Master of the Subaru
  • Gold Subscribers
  • 17,909 posts
  • West VA
Posted 24 September 2007 - 01:19 AM
dave are you going through with this? i think i just decided to swap mine as well 1996 Legacy LSi from Auto to Manual. i'll definitely be wanting to figure that cruise control out too. Josh has lots of cruise control details in his write up, great job boss i've looked at it a number of times over the year, looks like i'll get to use it!
are you going with hydraulic or cable clutch? are you starting soon?
#8 Hocrest
Hocrest
  • 1,344 posts
  • Cressona/Pittston
Posted 24 September 2007 - 11:38 AM
This got put on hold when the engine died. I needed a working car and swapped the engine and trans in two days. I had the 4EAT that we pulled out of the racer, and needed the car on the road...
If I keep the car, I still plan on swapping it. But as of right now I'm looking for a cheap 5-spd wagon for me, and the auto sedan can go to Melis's daughter.
As for hyd/cable it was going to depend entirely on what I found at the yard. :cool:
#9 subeman90
subeman90
    Soobologist
  • Moderator
  • 2,737 posts
  • Akron PA
Posted 25 September 2007 - 06:17 PM
cheap AWD 5 speed what??? legacy wagon, impreza wagon, OBS, OB? and what is cheap anyhow?????
There is a red loyale 5 speed 4wd wagon around here and I think it might be $1200 ish if that sparks your fancy
