EJ22t into an ea81?
8 replies to this topic
#1 cyberbackpacker
cyberbackpacker
    USMB Regular
  • PipPipPip
  • 83 posts
  • Holland, MI 49423
Posted 15 May 2007 - 03:31 PM
I have read the ea2ej pdf a good dozen times so far, but was wondering if anyone has put in an ej22t (or ej20t) into an ea81? I know suberdave has done it on an ea82, but I want to find out any potential hiccups/things to look for.
I will have the entire donor car, so hopefully this will help.
Also, what are your thoughts on running the ej22t without a hood scoop? I was thinking of trying to reroute the chimney so it vents outside of the engine compartment, but do not know how feasible/reasonable that is.
While I am at it, will I be able to add power steering to my ea81 using the turbo legacy bits? I have tired multiple searches on adding power-steering, but haven't produced what I am looking for.
Thanks in advance.
#2 suberdave
suberdave
    www.suberdave.com
  • 1,004 posts
  • Covington
Posted 15 May 2007 - 06:37 PM
shouldnt be all that hard. should be about the same as doing a 2.2 swap. but you will have to find a turbo EA81 crossmember or you will have to cut and weld yours for the uppipe.
the hood scoop on a turbo legacy is just for the turbo. there is no intercooler. so i think it would be just fine without a scoop.
any other questions just ask...
-=Suberdave=-
www.suberdave.com
#3 86BRATMAN
86BRATMAN
    Elite Master of the Subaru
  • 3,972 posts
  • Tazewell Virginia
Posted 15 May 2007 - 06:41 PM
RGuyver did a ej20T from a wrx into an 83 brat. Search for his username.
I would say that it would be best to grab the powersteering bits from another ea81 car, the ej rack is just too wide for the ea81 wheelbase.
#4 Matty B
Matty B
    Eat, Live, Breath Subaru
  • 342 posts
  • Swansea Tasmania
Posted 15 May 2007 - 07:46 PM
I have an EJ20SC in mine, I have SOHC EJ22 heads on an EJ20T motor.
The SOHC heads are 40mm narrower each and it allows it to fit between the framerails.
DOHC heads are just too wide without modification.
All the EJ stuff swaps and plugs together, look for whats in the parts department and lego it all together.
#5 Jerry DeMoss
Jerry DeMoss
    Pushrods 'O' Fury
  • 2,408 posts
  • Colorado
Posted 15 May 2007 - 10:35 PM
I still think that would be an insane project with a lightly modded ej22t in a little hatch with awd.:slobber: :burnout:
#6 cyberbackpacker
cyberbackpacker
    USMB Regular
  • PipPipPip
  • 83 posts
  • Holland, MI 49423
Posted 15 May 2007 - 11:32 PM
Well I have a little wagon that is going to get a lightly modded ej22t in it with hopefully awd if I can find a 5mt to mate to it. ;) I am stoked for this project.
#7 carfreak85
carfreak85
    Temple of Fuji
  • 5,313 posts
  • Cascadia
Posted 16 May 2007 - 01:04 PM
What is your projected timeline for this project? I have been planning a similar swap into my turbo coupe and any insight you can give me would be awesome!
#8 cyberbackpacker
cyberbackpacker
    USMB Regular
  • PipPipPip
  • 83 posts
  • Holland, MI 49423
Posted 16 May 2007 - 05:05 PM
Well I hope to have the motor in by July 1, with the wiring to follow afterwards.
However I am most likely going to swap in a different tranny at the same time, and swap in a steering rack with power steering too.
I am also hoping to keep the A/C. So... I will have to see. But July 1 is the goal to have it actually all bolted in.
I will be glad to share whatever I can, and I am sure will be asking many more questions before this is over.
#9 86BRATMAN
86BRATMAN
  • 3,972 posts
  • Tazewell Virginia
Posted 16 May 2007 - 06:47 PM
Yes, yes it would...
Calculated ET for the weight of a hatch with 200awhp is a 12.8-13.1 but it will vary by track and driver...
