L series: what lift do i need to run 31"s?
18 replies to this topic
#1 Fatz
Fatz
    USMB Regular
  • PipPipPip
  • 85 posts
  • Burnie, Tasmania
Posted 15 May 2007 - 09:58 PM
Hey all.
im about to lift up my l series wagon and put some 31 mudz under her.
I have ordered a 4" lift kit but can change it to a 6" in the next day or so.
Has anyone here done a lift to squeeze 31s under an L before?
If so what lift did you do to achieve this, and do you think a 4" will work?
Thanx all for your time.
Adam
#2 Phizinza
Phizinza
    Yip yip
  • 3,939 posts
  • South Australia
Posted 16 May 2007 - 12:21 AM
Most here don't know what an L-series is, it's the 85 to 89 style for those who don't.
I have seen a 6" lifted Brat with 30"s and seems the L can natrually take larger tires I'm guessing 6" with plenty of cutting will work.
#3 Fatz
Fatz
    USMB Regular
  • PipPipPip
  • 85 posts
  • Burnie, Tasmania
Posted 16 May 2007 - 12:23 AM
Cheers,
my mate runs 30s on his brumby with a 4" lift. he said he could fit 31s, but wouldnt be very comfy.
Was just curious if anyone knows with an 85-94 model.?
#4 Numbchux
Numbchux
    EJ conversion addict
  • 6,889 posts
  • Saginaw, MN
Posted 16 May 2007 - 01:17 AM
29s on a 4" lift requires a bunch of trimming, especially to allow the suspension to travel at all.
6" will probably still require some fender cutting....but it'll be a much better fit.
31s will REALLY hurt your gearing, and put alot of stress on axles though....
btw, we call them EA82s in the US.
#5 Phizinza
Phizinza
    Yip yip
  • 3,939 posts
  • South Australia
Posted 16 May 2007 - 02:13 AM
Pretty sure Fatz is running on a 4.44 VTD Auto or something like that. So, maybe it won't be so bad? Still, it's going to put a lot more strain on the torque converter.
What can't a subie do with 28.5"s that it can with 31"s?
#6 the_postie
the_postie
    USMB is life!
  • 145 posts
  • brisbane.aust
Posted 16 May 2007 - 02:23 AM
if you're gunna run the ej driveshafts and awd box you can get another 30 to 40mm with springs without any ill effect to said driveshafts say a 4inch kit with raised springs[pedders] gives you 5 more clearance under the guards.A 2" kit with 27 rubs a little so 4" would give you 29' with rubbing so 31 =?.Ive only done the maths with tape measure and car.
#7 Fatz
Fatz
    USMB Regular
  • PipPipPip
  • 85 posts
  • Burnie, Tasmania
Posted 16 May 2007 - 02:24 AM
I do have a spare 4.44 vtd auto box lying about. But this time im considering a manual 4.11 ej box. with the l series low range. If that doesnt work then ill go back to the auto.
As for the tyre size difference, prolli nothing at all. I just wanna do something different to the rest. No real reason or anything. Not too many BIGger L series in Aus. None in tassie.
Ill be running EJ Cvs up front with the coilover kit on my outback struts.
#8 Phizinza
Phizinza
    Yip yip
  • 3,939 posts
  • South Australia
Posted 16 May 2007 - 05:11 AM
I just wanna do something different to the rest. No real reason or anything. .
Good enough reason for me mate :cool:
I still think even with 4.11's you won't want to climb rocky slopes or things like that with 31"s. But for a sand rig 31"s would be awesome. You thinking 10.5" wide? Or wider?
#9 Fatz
Fatz
    USMB Regular
  • PipPipPip
  • 85 posts
  • Burnie, Tasmania
Posted 16 May 2007 - 06:28 AM
10.5s will be wide enough for me mate;)
#10 ezapar
ezapar
    [OTD]
  • Moderator
  • 27,377 posts
  • Seattle
Posted 16 May 2007 - 09:42 AM
Hey all.
Adam
Here's what 31/10.50s look like under a brat. You'll want a transfer case, your a/t 4.44 or whatever won't stand a chance against 31s. At least a 6 inch lift and lots of chopping and banging.
Yours is a wagon? You'll need to do some serious beating behind the doors I bet.
Your axles will be your new worst enemy unless you do a solid axle swap or something.
Posted Image
Posted Image
#11 Fatz
Fatz
    USMB Regular
  • PipPipPip
  • 85 posts
  • Burnie, Tasmania
Posted 16 May 2007 - 04:11 PM
ok cheers guys.
i have changed my order form a 4 ro a 6.
Will see how it goes;)
so no one has put this size on a L series? (except AA)
#12 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 4,046 posts
  • Bellingham
Posted 16 May 2007 - 05:10 PM
heres mine with some 30 x 9.50 -15s with a 6" lift
Posted Image
#13 Phizinza
Phizinza
    Yip yip
  • 3,939 posts
  • South Australia
Posted 16 May 2007 - 06:59 PM
fatz, is this on the sedan or a wagon?
What did mud rat run under his 5" lifted sedan?
#14 Fatz
Fatz
    USMB Regular
  • PipPipPip
  • 85 posts
  • Burnie, Tasmania
Posted 16 May 2007 - 07:02 PM
Wagon mate.
Im gunna sell the sedan soon.
mudrat ran 29s i think. Pretty sure he has a 3"bl and 2" worth of raised springs.
#15 the_postie
the_postie
    USMB is life!
  • 145 posts
  • brisbane.aust
Posted 16 May 2007 - 11:53 PM
THE last time i heard he was having 5 or 6" strut tops made up.
a 6"lifted L won't stand out much in Tassie.They look like a hilux coming down the road,maybe put some toyota badges on it.LOL
#16 Phizinza
Phizinza
    Yip yip
  • 3,939 posts
  • South Australia
Posted 16 May 2007 - 11:56 PM
He must love pulling driveshafts out, unless he has some way around eating them
#17 Fatz
Fatz
    USMB Regular
  • PipPipPip
  • 85 posts
  • Burnie, Tasmania
Posted 17 May 2007 - 12:01 AM
Haha. This 6" lifted L sereis will make a few heads turn.. Specially with the Bovs going hard with my TT setup;)
yummy
#18 Phizinza
Phizinza
    Yip yip
  • 3,939 posts
  • South Australia
Posted 17 May 2007 - 10:29 PM
If you go with a manual EJ AWD box you might want to look into fitting the pinion and front diff of a 4.44 box into a Liberty D/R box running L series low range. This should work just as long as the pinion on 4.44 boxes is the same fitment onto the centre diff as the 3.9 box.
This would help a LOT with your 31" tyres.
#19 Fatz
Fatz
    USMB Regular
  • PipPipPip
  • 85 posts
  • Burnie, Tasmania
Posted 17 May 2007 - 11:04 PM
sweet. cheers, ill look into it
