Coolant temp sensor..EA82
9 replies to this topic
#1 tidd1340
tidd1340
    USMB is life!
  • 139 posts
  • Buffalo,N.Y.
Posted 16 May 2007 - 09:53 PM
Mine is shot. I went with autopartsgiant. c om..said they had it..that was 4/22/07..i just filed a chargeback on my c/c as i have no part or refund,or any answers on where it is..anyone have a source for one of these? Or have a used one? The local stores want 99.00..hoped i could get one cheaper.
#2 rllywgn
rllywgn
    Diff Lock Dynamite!
  • 381 posts
  • Vegas Baby
Posted 17 May 2007 - 12:51 AM
try the junkyards if available.. most of them have two temp sensors.. which one do you need? t-stat housing or block?
#3 tidd1340
tidd1340
    USMB is life!
  • 139 posts
  • Buffalo,N.Y.
Posted 17 May 2007 - 05:43 AM
t-stat one..2 wires w/green plug. Older subies in NY are hard to find in the yards..they just rust away....
#4 daeron
daeron
    Cunning Linguist
  • 3,600 posts
  • West Palm Beach
Posted 17 May 2007 - 05:48 AM
you sure its not just a wiring problem? the wires, or the terminals, go bad far more often than the sensors themselves. Rust is the main culprit of "bad," that is why I ask.
#5 SmashedGlass
SmashedGlass
    Eat, Live, Breath Subaru
  • 669 posts
  • From CO, stuck in FL
Posted 17 May 2007 - 01:30 PM
wtf?? i think i paid about $15 for my sensor @ Checkers.....weird, man.
#6 Gloyale
Gloyale
    It's a sickness
  • 10,624 posts
  • Corvallis, OR PNW
Posted 17 May 2007 - 02:08 PM
MPFI uses a much more common style of sensor, connector plugs directly to it and there are no pigtails. The SPFI one has those wires and a connector. I believe you COULD use the MPFI one if you change the connector because they output in the same range. I am not sure if they have the same threads however.
#7 SubaRube
SubaRube
  • 256 posts
  • San Leandro, CA
Posted 17 May 2007 - 02:58 PM
I've been running an MPFI one in my SPFI for a year or so.
No problems so far.
For Comparison -
http://www.partsamer...ype=290&PTSet=A
MPFI
SPFI ('88-'94)
http://www.partsamer...ype=756&PTSet=A
SPFI ('86-'87 only -referred to as an "Air Charge Tempeperature Sensor")
For some reason they charge almost double for the '88-'94 SPFI version than the '86-'87 version of essentially the same part, just with a diff. connector. Weird.
Edit - I fixed all the links - should work now
#8 tidd1340
tidd1340
    USMB is life!
  • 139 posts
  • Buffalo,N.Y.
Posted 17 May 2007 - 04:25 PM
Subarube,can you post a p/n on the cheaper one? When i click the links i get just the expensive ones..thanks!!
#9 Gloyale
Gloyale
    It's a sickness
  • 10,624 posts
  • Corvallis, OR PNW
Posted 17 May 2007 - 04:26 PM
COOL!!! sticky this or submit the change over process to the USRM.
#10 daeron
daeron
    Cunning Linguist
  • 3,600 posts
  • West Palm Beach
Posted 17 May 2007 - 06:01 PM
its up to one of us to submit it to the USRM.
I just submitted Bucky92's photo of the fuse panel cover.
