'95 LOBW - Mysterious Noises While Braking...ABS?
8 replies to this topic
#1 subiedoobiedoo
subiedoobiedoo
    New User
  • PipPip
  • 28 posts
  • Seattle, WA
Posted 27 May 2007 - 04:15 PM
Since I've owned this car, when I leave my garage and apply the brakes for the first time since the engine's been fired up, the brakes feel like they lose pressure (momentarily) and a strange groaning/farting noise that sounds like it's coming from the forward part of the engine compartment.
It only used to happen leaving my building, but yesterday I experienced the same thing as I came to the end of a freeway off-ramp. The episode lasts approximately 1-2 seconds
Otherwise the brakes work fine...BTW, I have plenty of pedal and ample meat on the pads.
Most recent brake work: two months ago I had both ABS relay switches replaced when one failed.....but the above syndrome was happening PRIOR to the switch replacement.
I'm genereally not inclined to take a "wait-n-see" approach on my brake system, but nor do I want to buy any unnecessary repairs if this is a congential problem with the early LOBW brake system.
Thanks!
Mark
Ps. My '92 LOBW (w/ABS) never did anything like this.
#2 tcspeer
tcspeer
    1000+ Super USER!
  • 1,444 posts
  • Walnut Springs
Posted 27 May 2007 - 05:34 PM
The groaning is probably caused by contamination on the pads or shoes, you may be able to clean them with brake cleaner or you may have to replace them. The other noise I dont know what that might be.
#3 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 27 May 2007 - 06:28 PM
Hi, not sure if this is helpful but here it is:
ABS System Check (EndWrench)
The ABS Electronic Control Unit checks all system components, including the Hydraulic Control Unit, each time the vehicle is started. When the Hydraulic Control Unit is operating during this checking period, the owner/technician may hear a noise/buzzing coming from the engine compartment.
They may also feel the brake pedal pulsating slightly if their foot is on the brake pedal. This pulsating of the brake pedal may be more noticeable when backing down a slight grade (sloping driveway). It may also be felt when moving forward. The check is not performed until a speed sensor input is received by the ABS Electronic Control Unit. This is a normal function and no repairs should be attempted.
#4 OB99W
OB99W
    Elite Master of the Subaru
  • 3,315 posts
  • Ithaca
Posted 27 May 2007 - 07:20 PM
Any ABS lamp indication? Weather/road conditions at time you experienced the condition? (Was it raining in Seattle? :) )
#5 Seahag1978
Seahag1978
    1000+ Super USER!
  • 1,390 posts
  • Witch City
Posted 27 May 2007 - 07:29 PM
Could be just "morning sickness". I've never owned a Subaru that hasn't had one form or another... squeaks, squeals, moans, groans, thumps, thuds or chatter. My Baja is one megahertz below a dog whistle... makes you cringe... like Quint drawing his nails down the chalkboard in Jaws.
If it's humid and damp, my '86 damn near howls at the moon, scares an unfamiliar driver (Tim) and lasts as long as the rain/humidity does :)
#6 Suzam
Suzam
    1000+ Super USER!
  • 1,213 posts
  • Wilmington, Delaware
Posted 27 May 2007 - 08:29 PM
Our MY95 does after a startup too, totally normal ABS system self check. As for the end of the ramp, you may have been braking hard and hit an oil patch or some other slippery spot. I've felt the ABS kick in while braking hard or on an curve when the tires were turning at different speeds.
#7 subiedoobiedoo
subiedoobiedoo
    New User
  • PipPip
  • 28 posts
  • Seattle, WA
Posted 28 May 2007 - 01:56 AM
No ABS lamp....and the roads were (unusually!) dry.
According to the other posts, looks like everything's normal!!!
Thanks for the feedback!
MM
#8 SUBARU3
SUBARU3
    Moderator
  • Moderator
  • 2,825 posts
  • Dallas, Ft. Worth, Texas
Posted 28 May 2007 - 03:27 AM
My 95 Legacy does the same thing. It's normal. Just a self check.
Todd
#9 subiedoobiedoo
subiedoobiedoo
    New User
  • PipPip
  • 28 posts
  • Seattle, WA
Posted 28 May 2007 - 11:18 PM
Todd
Thanks!
MM
