largest tires *UPDATE*
14 replies to this topic
#1 SoobGoob
SoobGoob
    Subaru Fanatic!
  • 402 posts
  • Portland
Posted 30 May 2007 - 03:49 PM
ok so i searched and couldnt find anything spefic for my car. so sorry to repeat a question asked a million times. but i have some 205/75 R13's on some chevy lugs and they are already drilled. can i fit them on myloyale with minimal or no cutting in the rear. i dont mind cutting the front. any help?
#2 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,193 posts
  • WA
Posted 30 May 2007 - 05:17 PM
You did read the sticky at the top of the page?
http://www.ultimates...ead.php?t=62289
And why would you put 13's on a chevy lug wheel?
#3 Phizinza
Phizinza
    Yip yip
  • 3,939 posts
  • South Australia
Posted 31 May 2007 - 01:07 AM
If they are 13's and not 14's then they should fit no worries. Ofcause it all depends on the wheels offset......
205/75R13 is 25.1", plus an inch if you ment 14's...
#4 SoobGoob
SoobGoob
    Subaru Fanatic!
  • 402 posts
  • Portland
Posted 31 May 2007 - 01:33 AM
yes turbone that was the first i checked. wasnt spefic enough. and they were on 13 chevy redrilled rims. 25.5 inches across. (got them for free) but after a day of cutting and pounding in 90 degree weather i got them all to fit with no rubbing. now i just need something to put where i cut the fender. any ideas? pics soon to come. its looks great even with no lift. very excited :banana:
#5 Phizinza
Phizinza
    Yip yip
  • 3,939 posts
  • South Australia
Posted 31 May 2007 - 02:11 AM
.. Paint?
#6 SoobGoob
SoobGoob
    Subaru Fanatic!
  • 402 posts
  • Portland
Posted 31 May 2007 - 12:04 PM
haha no i meant some sort of plastic trim. the cut was not a perfect shape and i dont like the sharp edge there so im looking for something to make it look a little cleaner
#7 SoobGoob
SoobGoob
    Subaru Fanatic!
  • 402 posts
  • Portland
Posted 31 May 2007 - 07:10 PM
les schwab wouldnt alinge my tires!?! because "they were too big" so now i have to swap the stock ones on to get an alingment. what a joke:dead:
#8 SoobGoob
SoobGoob
    Subaru Fanatic!
  • 402 posts
  • Portland
Posted 31 May 2007 - 11:57 PM
with the new tires on my car kind of shakes? i dont know the best way to put it. bouces slilghtly? could this be off balance tires. also it pulls more to the left then before i knew the alingment was off already but is it just more noticeable with larger tires? basically what im asking is if these are problems that can be taken care of with alingment and balancing? and is there anyway to make my suspension stiffer/longer? my rears run close to the well and i know one big bump would make them rub with my worn out suspension...
#9 SoobGoob
SoobGoob
    Subaru Fanatic!
  • 402 posts
  • Portland
Posted 01 June 2007 - 12:23 AM
i heard something about honda springs?
#10 P K
P K
    Devil Dog Liaison
  • 1,171 posts
  • Omicron Persei Diego
Posted 01 June 2007 - 12:54 AM
Whoa, stop the press.
Where do you get 205/75-13 tires?
Do you have a pic?
Thanks, r/PK
#11 SoobGoob
SoobGoob
    Subaru Fanatic!
  • 402 posts
  • Portland
Posted 01 June 2007 - 01:39 AM
they are some wildcats GD traded me last summer. i dont know where he got them
#12 SoobGoob
SoobGoob
    Subaru Fanatic!
  • 402 posts
  • Portland
Posted 01 June 2007 - 11:54 AM
correction i went to take pictures they are 14s. sorry for the typo. but i decided im just going with the sjr lift. WHOOHOO
#13 chazmataz
chazmataz
    I'm a Mud Addict
  • 673 posts
  • Estacada
Posted 01 June 2007 - 11:55 PM
bigger tires then stock shouldn't have stopped les schwab from doing an alignment. i have never heard of that. what les schwab was it??????
you come to my store and i'll align it for you, unless you have wornout parts then they would have to be replaced. an alignment won't always stop a car from pulling, other things can cause a pull to. mine pulls i just live with it because i've mod the piss out of it and i'm running 15".
#14 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,193 posts
  • WA
Posted 03 June 2007 - 11:21 AM
I'm not sure (I havent had a alignment in over 20yrs) but maybe the new setups are computerised and when you punch in 14in tires for a Subaru for the car info it comes up with a error.
#15 Phizinza
Phizinza
    Yip yip
  • 3,939 posts
  • South Australia
Posted 05 June 2007 - 11:09 PM
I use a tape measure and align myself.
What can they really align on a stock EA82?? Steering is about it. Not hard to do it yourself really.
