Guest pnfrank1234 Posted July 23, 2003 Share Posted July 23, 2003 I would like to install a tran fluid cooler in my legacy gt, but first i want to make sure that the fluid is indeed hot (and see when the cooler goes in how big a temperature drop i get). where can i buy such a temperature gauge and how difficult an install would it be? thanks for any help. Quote Link to comment Share on other sites More sharing options...
Guest hocrest Posted July 23, 2003 Share Posted July 23, 2003 I can't help you, but, you may want to check out the board on <a href="http://www.subaru-svx.net" target="top">http://www.subaru-svx.net</a>, this is an issue that more SVX owners have dealt with. And unlike ours, their Search Engine works:) Quote Link to comment Share on other sites More sharing options...
Guest trinket Posted July 24, 2003 Share Posted July 24, 2003 Jeg's or Summit Racing has a kit with filter that has a temp. gauge as part of the package. I've seen it in their catalogs many times. trinket Quote Link to comment Share on other sites More sharing options...
Guest meep424 Posted July 24, 2003 Share Posted July 24, 2003 splice the cooler lines and insert a T fitting. Screw the sensor in the 3rd opening (may require brass adapters). If electrical, you'll have to ground the T. Mike Quote Link to comment Share on other sites More sharing options...
