CV Axle: junkyard or aftermarket rebuild?
21 replies to this topic
#1 brighton98
brighton98
    USMB Regular
  • PipPipPip
  • 72 posts
  • Guthrie, Iowa
Posted 18 June 2007 - 07:02 PM
I need to replace the right front CV axle due to a torn boot. The OEM Subaru rebuild is $188; I'd trying to go "on the cheap." I've read many bad posts about parts store rebuilds--too short, wrong splines, etc. Would a used one,with good boots, be an acceptable alternative? The car only sees about100 mi./wk., and Id rather save for the 120K timing belt! TIA for your help.
#2 Manarius
Manarius
    1995 Subaru SVX LSi
  • 1,609 posts
  • Grantham
Posted 18 June 2007 - 07:13 PM
Used would be all right - but be weary of the boots.
#3 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 18 June 2007 - 07:18 PM
Yes if you can a good used salvage yard one that would be a reasonable choice (if you cna tell it too is not some parts store rebuild..). I too have seen a number of bad posts about the parts store rebuilds, including but not limited to some weird vibration when stopped in drive aftewards. Another option would be mweaxles not sure how they compare to Subaru rebuild prices but those should be good axles.
#4 Manarius
Manarius
    1995 Subaru SVX LSi
  • 1,609 posts
  • Grantham
Posted 18 June 2007 - 07:19 PM
That weird vibration is transmission and drivetrain stress - not bad axles.
#5 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 18 June 2007 - 07:25 PM
Oh ok cool. Wasn't sure the cause of the vibration, just many a post indicating it happening after half shaft replacement, also on other boards too.
#6 Manarius
Manarius
    1995 Subaru SVX LSi
  • 1,609 posts
  • Grantham
Posted 18 June 2007 - 07:29 PM
I just wanted to clear that up - I've seen a lot of people complain about axles causing vibration at stop. My car had the same vibration at stop in Drive when the original axles were on it (with good joints). The AWD system and drivetrain when stopped is still getting force from the engine (it's like trying to hold a car back while giving it gas - something has to vibrate).
#7 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 18 June 2007 - 07:32 PM
Good to know the cause. It always seemed a little mysterious. A popular poster has said it may be related to misbalance between the half shafts and noise-vibration-harshness analysis.
#8 ericem
ericem
    First Gen Legacy Master
  • 2,477 posts
  • CANADA Maple,ON
Posted 18 June 2007 - 07:46 PM
I thought it was because of worn transmission mounts. The torque converter disengages a bit eh?
#9 Dickensheets
Dickensheets
    Subaru Fanatic!
  • 452 posts
  • Las Cruces, NM
Posted 18 June 2007 - 08:34 PM
I have good luck with the remans from O'reilly Auto Parts. Fit perfectly. $65.
rd
#10 chef_tim
chef_tim
    Romans 5:8
  • 4,780 posts
  • Renner, SD
Posted 18 June 2007 - 08:56 PM
Check these guys out, best NEW axle I've found. Also available at one of the chain auto parts places, Auto Zone I think.
http://www.autopn.co...choose_make.asp
#11 86ruguy
86ruguy
    Subaru Fanatic!
  • 381 posts
  • tacoma
Posted 18 June 2007 - 09:03 PM
fair pricing. i got some here in town for $95 a side. worn out boot on one side and clicking on the other.
I would also always go new. just my $.02
#12 ccrinc
ccrinc
    The Subaru Whisperer
  • 1,031 posts
  • Denver, CO
Posted 18 June 2007 - 09:27 PM
You can't do better than MWE Axles, IMHO. Marshall is a colleague of ours, not part of CCR in any way. I won't use anybody else's on my own cars.
You can reach him here: http://ccrengines.com/mwe/index.html
Emily
http://www.ccrengines.com
#13 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 19 June 2007 - 05:29 AM
Yes I've heard great things about mweaxles remanufactured Subaru axles (and ccrengines :) ) This may be a good option for the OP, who wants to avoid aftermarket units but not pay the price for a Subaru rebuild. Wow I just checked the prices on the site and those are not much more than the parts store rebuilds anyway.
#14 xrturbo
xrturbo
    Subaru Fanatic!
  • 368 posts
  • allentown
Posted 19 June 2007 - 06:38 PM
If you know someone that has a shop you can get remans from advance for $40. If you are getting a used one try to get one from a 00 and up car. The boots have more convolutions and hold up better. You just have to knock the tone ring off the end before you install it.
#15 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 21 June 2007 - 07:02 AM
I was just looking in the endwrench magazine and it says Subaru reman axles are done by Cardone.
#16 idosubaru
idosubaru
    Elite Master of the Subaru
  • 23,768 posts
  • East Coast
Posted 21 June 2007 - 08:03 AM
this doesn't necessarily mean the Subaru reman's and any Cardone aftermarkets are identical. Subaru makes some attempt at keeping a certain level of quality...tolerances, parts used in the rebuild, etc. Cardone is on it's own though to supply the aftermarket world and those parts aren't required to meet those same standards. there's a good chance, but i'm also not one to put anything past a company. if they can save a buck, they may.
wonder if there's a conclusive way to find out?
#17 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 21 June 2007 - 11:22 AM
True, they probably are different specs. The ad for says "Remanufacturerd for Subaru by Cardone" Actually here's the whole article: Subaru Reman CV Drive Axles http://endwrench.com...7FebRemanEW.pdf
"designed to meet Subaru OE specs - no other axle in the aftermarket meets that requiremment"
"boots specifically formulated to meet sringent Subaru specs for ozone/haet resistance and high spped oscillating and impact durabililty"
"All axles are supplied 100% with a new axle nut, dust shields and roll pin"
"All outer joints hae 100% resurfaced ball tracks to ensure long-term durability"
#18 chef_tim
chef_tim
    Romans 5:8
  • 4,780 posts
  • Renner, SD
Posted 21 June 2007 - 11:26 AM
I need an axle on my OBW I'll be giving the MWE axle a shot. I like to support our community and if Em is giving them thumbs up they've got to be good!!! Let you know when i get them, Tim
#19 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 21 June 2007 - 11:48 AM
Good idea. When I need axles I'm planning to go with MWE remans too. Price doesn't seem much more than the auto parts rebuilds, and a lot less than the Subaru reman.
#20 TheYeti
TheYeti
    Carp in Denim!
  • 505 posts
  • Arvada
Posted 21 June 2007 - 12:40 PM
Contact Marshall at CCR.
That is all :)
#21 ccrinc
ccrinc
  • 1,031 posts
  • Denver, CO
Posted 21 June 2007 - 05:26 PM
You can email him through our website or his phone number is (303) 522-8070.
Emily
#22 chef_tim
chef_tim
    Romans 5:8
  • 4,780 posts
  • Renner, SD
Posted 11 July 2007 - 05:50 PM
I have to take this back. I gave him a call and after shipping and all it was way more expensive then a new GCK from AZ so I went with them. If it was a case were I could just go pick up an axle I'd be far more inclined to go that route. Tim
