bull bar attachment
5 replies to this topic
#1 opelsuby
opelsuby
    USMB Regular
  • PipPipPip
  • 120 posts
Posted 20 June 2007 - 08:24 AM
:confused: '81 GL Wagon 4wd Manual tranny. I got this bull bar from a member. It suuposedly fits on my rig. Problem is I can't figure out where to attach the lower portion. See photograph #2. Wher it would slide up, all there is is some thin sheet metal. Also see photograph#2. Do I have the wrong bar or what am i missing? yeah I know the Soob looks rough. It is a work in progress. Any and all help appreciated. Photos of yours would be super.
#2 Sweet82
Sweet82
    Elite Master of the Subaru
  • 3,274 posts
  • Salt Lake City
Posted 20 June 2007 - 10:32 AM
I have never seen a mount like that,
My bar mounted to the shipping ties and bumper.
From the looks and hole positions,
I'd say it mounts higher in the rear.
Most likely to the actual frame rails.
Possibly to the motor mount holes/bolts?
This would sit the bar level and be stronger?
Put the front more level/leaning forward and
see if it wants to mount to the frame rails...?
In the pic it's leaning back
#3 WoodsWagon
WoodsWagon
    Formerly 91Loyale
  • 4,102 posts
  • NH
Posted 20 June 2007 - 10:59 AM
THe bolt spacing looks like it may use the engine crossmember bolts to attach to the body. If it can reach there, that's probably where it hooks to.
#4 bratsrus1
bratsrus1
    Race car
  • 1,316 posts
  • Selah Washington
Posted 20 June 2007 - 02:44 PM
Hi This is Jerry, those brackets bolt up to the engine cross member. You bolt that part up first then hook up the bolts to the bumper. Thanks Jerry
#5 opelsuby
opelsuby
    USMB Regular
  • PipPipPip
  • 120 posts
Posted 21 June 2007 - 08:08 AM
Thanks Jerry. i couldn't remember you Forum name. I'll peek under there again and look for the crossmember.
#6 lonnie
lonnie
    USMB Regular
  • PipPipPip
  • 93 posts
  • oregon city
Posted 22 June 2007 - 12:33 PM
mounted push bar this morn on my 85 brat. suggest you:
1. jack up rig and place stands;
2. jack up and support motor cross member;
3. release cross member bolts;
4. bolt up rear most slot on either side (do not tighten)
5. use second jack to raise front portion of bar (i had to trim bumperettes and really push to get past bumper);
6. bolt up foward slots on either side (do not tighten)
7. bots up foward attachment bars ( it should now be obvious where they fit) (do not tighten)
8. now tighten slot bolts
9. now tighten forward attachment bars
hope this helps
ps. on a later madel brat i also had to remove lower chrome bar which connects the two bumperettes.
